Question about Whirlpool Washing Machines
WFS1273 FRONT LOAD WASHING MACHINE. I REMOVED THE BOTTOM HOSE BOOT AS IT WAS BLOCKED WITH A SOCK. WHEN THE HOSE WAS REMOVED A RUBBER SEAL & A CHECK BALL FELL OUT. WHICH WAY DO THESE GO BACK IN? THANKS PETER STOKES.
    President:
  • 1,462 Answers
Forget them and just refit the hose
Posted on Aug 10, 2008
SOURCE:
My Epic Z front load is leaking water . It looks like the gray rubber on the door is the cause. The machine is only 18 months old
In the front on the bottom of the gray seal is two drain holes, make sure there is not an obstruction in these drain holes such as a small sock .
May 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
My washing machine LG WD1238C keeps showing error message OE hose is not blocked or filter blocked does not finish any cycle or work correctly
This sounds like a blockage in the small hose connected to the waste pump. Take the lid off and find the waste pump down near the bottom of the machine below the drum, then remove any one of the hoses connected to the waste pump and check inside the pump to make sure the fan can spin using your fingures, maybe a small kids sock or similar jammed in there, if nothing in the pump check both pipes on the waste pump
Dec 27, 2010 | LG WM-2277HW Front Load Washer
The washing machine (front Load) leaks water
hello you may have an hole in the door seal check the rubber seal around the door if this is ok then check rubber hose on the pump
regards
shaun
Sep 01, 2010 | EuroTech EWF172 Front Load Washer
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washing machine is fillig up and washing,but its not emptying the water? i have now un blocked the filter but the problem is still there?
Check is the outlet rubber hose bent too tight. Also sometimes a sock or similar can enter the pipe. Put the outlet hose into the sink and see does it empty. This will indicate which way the blockage is.
Nov 02, 2009 | Creda W100FW Front Load Washer
Turn the wash cycle to on and the water comes out of the detergent dispenser.
The hose from the dispenser to the tub is blocked. Did someone put a sock or something in the dispenser to bleach it? The water has taken it and pushed it into the hose. You may have to remove the rubber boot around the door to access the hose.
Sep 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Blocked drum
Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and holds the drum. Check the outer tub port- open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. Good luck !
Aug 31, 2007 | GE WHRE5260E Top Load Washer
Washing Machines Logo
173 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
