Question about Canon LASER SHOT LBP-5200 Printer
Canon Printed LBP 5200 Error Code E000
I have a Canon LBP 5200 laer printer and cannot print. The error code is E000. How do I fix this problem? Rob. Email: rdulhunty@devcapital.com.au
  • 7 more comments
  • rdulhunty Aug 10, 2008
    Where is the solution?
    Your answer was 'This error indicates fuser error, its not heating up.'
    What does that mean?
    What is the solution to this issue so that I can continue printing now?
    I have a Canon LBP 5200 laser printer and cannot print. The error code is E000. How do I fix this problem? Rob. Email: rdulhunty@devcapital.com.au
    The solution provided was 'This error indicates fuser error, its not heating up.'
    What's the solution?
    Solution?
  • Anonymous Mar 22, 2014
    pls send
  • Anonymous Mar 23, 2014
    i am getting an error code 5200
  • Anonymous Mar 25, 2014
    my printer is error 5200 and not printing
  • Anonymous Mar 27, 2014
    service error 5200
    Guru:
  • 1,894 Answers
Posted on Aug 10, 2008
  • dewan nafees ahmed Aug 10, 2008
    1. Turn the printer off, wait 10 minutes, and
    then turn the printer on. 2. If the message persists, reseat the fuser.
    If that does not work, replace the fuser. To check the fuser, turn
    the printer off and remove the fuser. Measure the resistance between
    the fuser connectors. If it is not within the proper range, replace
    the fuser. If there is not continuity between the fuser connectors
    neutral and hot with the fuser removed, replace the fuser. If the
    problem is not related to the fuser, replace the engine controller
    board.
    please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service more
    function/clear/error/ok/ exit service mode and cycle power.
    fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
    Fuser error codes cannot be reset by power cycling the machine even
    though that is what the display tells you to do. In order to reset the
    fuser error code you must enter the service mode & reset the code.
    To enter the service mode:
    press"Additional Functions" button (looks like a picture of a head with a star inside)
    press the #2 and #8 at the same time (simultaneousley)
    press "additional functions" again
    The display should show a choice of
    copier,feeder,sorter,fax,or board service modes
    Select copier
    select clear
    select ERR
    press OK
    Turn power off & back on.
    ****IMPORTANT****
    After
    clearing error stay at the machine to see if it comes to ready. The
    fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can
    only be cleared through the service mode because a technician should
    inspect the fuser to verify there is nothing faulty that could possibly
    start a fire. If you enter the service mode & clear the error,
    power cycle the machine & during warm up the machine throws a code
    again- turn it off, unplug it & call a tech for fuser repair.
    Good Luck!!
    Master:
  • 763 Answers
Try reinstalling the driver of your printer to your computer. it might solve the problem. make sure that you connect it properly and be detected by your computer. hope that helps!
CHARCOIS
Error problem
http://forum.testcopy.net/threads/how-to-fix-errors-based-on-error-code-table-of-canon-lbp-3100-3108-3010-3150.693/
Sep 29, 2014 | Canon I-Sensys Mf4410 All-In-One Laser...
Error code e000 0000
If Error code is E000 then may be major cause:
+ The thermistor has an open circuit or short curcuit
+ The heater has an open circut. The thermal fuse has blown
+ The power supply PCB has a fault
+ The engine controller PCB has a fault
To Fix Error code E000 of Canon LassetJet LBP-3300 printer, you can try the following:
+ Check connector of the fixing film unit
+ Replace the fixing film unit
+ Replace the power supply PCB
+ Replace the engine controller PCB
This is not a job for a novice. Get a service technician to service the unit.
Apr 23, 2014 | Canon LBP3300
E1970000-Model No.- Canon LBP 2900B
Jan 26, 2014 | Canon LASER SHOT LBP-2900 Printer
Fixing unit error. Turn off and unplug the printer, and then contact the store where you purchased the printer or your service representative. When contacting the service representative, inform them of...
This is a print head error. If you have a cleaning option on the printer menu, please try that. If you dont, then you can remove the in cartridge and try cleaning the head with 1-tips and water or alcohol.
Jan 19, 2014 | Canon LASER SHOT LBP-2900 Printer
Error E000 can't print
When your printer fuser unite is not active to work then show Error E000 or fuse is out of order or work.Check it then solve your problem.
Dec 11, 2009 | Canon LASER SHOT LBP-5200 Printer
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
CANON LBP 5200 error code100
Canon Laser all in one printer copy fax laser
when setting the printing preverencens it comes in the Spanich
lanquis how can i change it all the other ones are in the Englich installed from the driver It only do this in Vista not in XP pro
My old laptop in XP Pro works fine
my new laptop Toshiba and vista that is what happen
Jan 07, 2008 | Canon LASER SHOT LBP-5200 Printer
Canon LASER SHOT LBP-5200 Printer Logo
1,948 people viewed this question
old marine
old marine
