Question about Toshiba Tecra M1 PC Laptops
Memory upgrade How do i replace the memory? I have taken all the screws out but cannot pull the 2 halves apart.
    Novelist:
  • 202 Answers
This is the link
http://www.memorystock.com/memory/ToshibaTecraM1.html
In that web page come down little bit u have
1)Memory Installation Video Link
2)Laptop Memory SODIMM Installation Guide Link
Posted on Aug 13, 2008
How do i dissamble the unit to replace the main control
take out all the screws you can find.... then look for the screws you cant find.... pry apart carefully (or angrily....it's your choice) . you may need a thin putty knife or screwdriver....or box cutter to break the bonds of any glued seams you may encounter. on e the main body is taken apart (usually 2 halves sometimes more) you should be able to locate the parts you need to replace.
Nov 09, 2013 | Vacuums
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
My e1705 dell inspiron, flashes the caps lock muliple times upon turning off and the screen doesnt turn on, I was told that reseting the memory would help. my question...how do i reset the memory?
Hi there!
The memory is located at the bottom of the laptop in the middle, so flip the laptop over, locate the memory, it has a cover you'll need a screw driver and you will be taking out 2 screws, after you have taken out the screws, slide the memory cover and remove it, then you will see the memory, there will be a retaining clip holding the memory it should be in each side of the memory, after that pull the memory up to 45 degrees angle, lift the memory then pull the memory from the connector, If you have 2 memories just do the same process.
Hope this helps!
May 31, 2010 | Dell Inspiron E1705 Notebook
Samsung 170 MP LCD Monitor Disassembly
The plastic case also has latches along the sides, top and bottom. Take a small flat blade screwdriver and go between the 2 halves of the case. The 2 pieces should open just a bit, now move the screwdrivers along the seam between the 2 halves. about every 2-4 inches there is a clip that needs to be released. You can release it by applying a small amount of pressure by each clip and moving down to the next one while pulling the case apart.
Buddy
Corporate Compuer
over 21 years repairing PCs and printers
Jun 17, 2009 | Samsung SyncMaster 17" TFT LCD Monitor
Upgrading the RAM. Can't find where to put it.
The computer has two memory expansion slots—Slot A and
Slot B. You can install one or two memory modules.
1 Shut down your computer completely using the Shut Down
command.
2 Unplug the computer.
CAUTION: Installing a memory module with the computer’s
power on may damage the computer, the module, or both.
3 Close the display panel and remove any cables you may have
connected.
4 Turn the computer upside down.
5 Locate and remove the screws that hold the cover plate in
place, then remove the cover from the bay.
Removing the memory module cover
CAUTION: Static electricity can damage the memory module.
Before you handle the module, touch a grounded metal
surface to discharge any static electricity you may have built
up.
To avoid damaging the memory module, be careful not to
touch its pin connector on the side you insert into the
computer.
6 Remove the new memory module from its antistatic
packaging.
7 Insert the memory module in the slot and gently press it down
into place.
The clips on either side of the module will click to secure the
module.
Inserting the memory module into the slot
8 Replace the cover plate and the screws.
9 Turn the computer over and restart it.
When you turn on the computer, it automatically recognizes
the additional memory.
Removing a memory module
If you need to remove a memory module:
1 Complete steps 1–6 in “Installing a memory module” to shut
down the computer and open the memory module cover.
2 Pull the clips away from the memory module.
The memory module pops partially out of the slot.
Adding memory
Pulling the clips away from the memory module
3 Carefully remove the module from the slot.
4 Replace the cover plate and screws.
May 15, 2009 | Toshiba Satellite Pro 6100 Notebook
Memory upgrade
1. Determine what memory you have, how much your laptop will take, and how much you need. Go to www.crucial.com, and it can automatically scan your computer and tell you what you have and what it will take.
2. On the bottom is an access door for the memory. Remove the screw and pop open the access door.
3. Either replace or add the new memory module into the slot(s). They go in at a 45 degree angle, then press down for the locking tabs to lock the memory into place. To remove the memory, you just pull out on the locking tabs and the memory will raise up slightly allowing you to remove it.
4. Replace the access door and screw.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | Acer Aspire 5100 Notebook
Memory upgrade
The memory should be DDR II Ram. To find how much ram you have simply click on Start then right click on "My Computer" and click properties. Chances are you have 512 ram. It will tell you in the lower right hand side along with your processer and windows version. Once you have found out how much ram you have, turn off your computer flip it upside down and pull out the battery. Then you should see a cover with one or two screws in it that measures about 3 inch by 4 inch. Remove the screws and take the cover off. This is where your memory goes. If there is 512 memory in your computer you will either have 1 512 memory stick or 2 256 sitcks. Remember that any time you upgrade memory it is best to take out the old memory and replace with either one stick of higher ram or two of equal ram. Never mis a 512 and a 256 or 512 and 1gig ect. Take the ram stick/sticks out and bring them down to the store with you just so as to get the correct memory. Also, remember when you replace the memory, if you are just upgrading to one 1gig stick to put it in the A DIMM slot. This is the primary ram slot.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
Upgrading memory on a V25 Samsung laptop
Make sure you are ONLY taking off the cover needed to change the RAM. Other screws may hold sensitive parts in place. Go to the laptops makers website and see which screws need to be removed. Its a good idea to also see if you need to change any settings in the BIOS once RAM is installed.
Apr 27, 2008 | Computers & Internet
Memory upgrade
I think these machine have a GDI Printer Board and the mem stick will go in that, now that jibberish means, that somewhere usally external rear or sides there is a board that is slotted into the machine, this thing will have 2 turnable long finger screws about 7cm apart attached to a rectangle face with gdi or expansion board written on it
 Power off/undue screws remove board, insert memory module etc
Check driver on pc is GDI for copier and that it also has correct extra memory options selected
Hope this helps I'm not sure on the model but that how most of em r
Oct 16, 2007 | Toshiba e-Studio163 Copier
Toshiba Tecra M1 PC Laptops Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
