Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
DVD player only plays in black and white
Hi, we have a 32" Sony Trinitron with surround sound. It will only play DVD's in black and white - it used to play in colour. Have you any suggestions? Vic
  • viclin120 Aug 10, 2008
    Do not have a manual as we bought it secondhand.
  • 10,594 Answers
Pls check color system option in your tv and select by remote, NTSC 5.38MHz for color reception
Posted on Aug 12, 2008
    Genius:
  • 1,011 Answers
Dear,
there must be some options either in tv mod or in dvd, is not properly selected..
check both manual in details...
regards,
dont forget to rate
Posted on Aug 10, 2008
I have a sony triniton color tv medel 3 KV-DR34M89. How do i connecft and play a DVD on it.. i treid connect the yellow,red and white cables on all the slots but no success. please advise
Connect cables:
Connect yellow to yellow (dvd player to TV)
Connect white to white (dvd player to TV)
Power on DVD and TV and insert a DVD into the player, press PLAY.
Use your TV remote to select the proper input:
Your remote should have a button like INPUT SELECT or Video, keep pressing until you see the DVD players output.
Feb 20, 2011 | Sony FD Trinitron WEGA KD-27FS170 TV
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Dvd's are playing black & white via sound surround system
Check first your dvd player settings if it is in PAL or NTSC.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
DVDs on my Sony SLV-D350P DVD/VHS player play in black and white
First try a good quality dvd cleaner. If that does not cure the problem then the video cable may have went bad. I had a system that the cables were never touched & after a few years it needed replaced in order to get my picture back. Hope this helps & please take a moment to rate my answer. Thanks.
Feb 08, 2009 | Sony SLV-D350P DVD Player/VCR
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Mar 27, 2008 | Sony DAV-S500 System
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
188 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
