My Ion ttusb10 turntable plays the record until about the last quarter then the record sticks and doesn't ever go past that point on any record i play?
  • Anonymous May 16, 2009
    I have the exact same problem. Sorry, but I find the suggested solution incomprehisible.
  • DonWatson May 16, 2009
    I have the exact same problem. Sorry but I find the suggested solution incomprehensible.
  • 2,071 Answers
It is motor problem that sticks , maybe the gear their is misalign,try to check this out ..
hope this may help;
dont forget to rate;
Posted on Aug 10, 2008
Is there ANY way of removing ALL ambient noise (whether minute or loud) when recording from turntable onto my computer? It seems to br present in all remedies I try.
Yes one of the simple ways is to wet the record before you play it. You may even wash it under running water to clean the groove.And play it while it is still wet.
Jul 15, 2011 | ION Audio TTUSB10 Turntable
Just bought a used ion ttusb10 as is and it doesn't turn. would it be practical to fix this or am I just screwed?
You should contact the place you bought it from, they should rectify this problem, unless it was advertised as not working. Otherwise if you are lucky it could be a belt drive turntable and the belt has come off, otherwise you are screwed, and it's going to cost as much to fix it as what you paid for it.
Jul 09, 2011 | ION Audio TTUSB10 Turntable
What is required to convert 78rpm records to mp3 format?
The cartridge must have a stylus for 78rpm records. If the turntable does not have a 78 speed play it back at 45rpm. Record it and using the software you have or get one such as Audio Cleaning Lab, just select the option to convert from 45 to 78. You can then carry out any audio modifications to clean it up, then save it as an MP3.
Never use a 45/33 stylus to play a 78 and never use a 78 to play a 45/33 record.
Nov 07, 2010 | ION Audio TTUSB10 Turntable
Turntable plays fine, but when I play the converted tracks in itunes, they are very low
Try turning up the GAIN (a knob at the back of the turntable). This should increase the recording level.
Feb 16, 2010 | ION Audio TTUSB10 Turntable
ION TTSUSB10 does not record stero
I solved the problem by using www.wiki.audacityteam.org home page under the technology heading and clicking on USB turntables. The mixer had to be changed to 2 channels. (stereo)
Jan 05, 2010 | ION Audio TTUSB10 Turntable
ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Dec 03, 2009 | ION Audio TTUSB10 Turntable
No sound
Try setting the recordsettings of ur soundcard to "record what you hear". This way it will record ALL the sounds that are produced in windows. Warning: this also means that it could record an windows systemsound as well.
Jan 01, 2009 | ION Audio TTUSB10 Turntable
Record will not play to end.
There is a mechanism underneath the deck which senses "end of record". This is operating too early and will require adjustment.
Dec 30, 2008 | ION Audio TTUSB10 Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
56 people viewed this question
 Grubhead
Grubhead
