Duraband DBD VR01
Blown power supply
IC 101 Marked as 1207a PAJP 8 PIN DIL
R100A
C117A
R108A
Can you supply detals on ic and values of other listed components and were to obtain service components
Call manufacturer service/parts department for part numbers and ordering instructions
Posted on Aug 15, 2008
Can i have TCL 2127 model power unit IC's pin 8 resistor value
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Schematic diagrams to some popular model TVs are given.
Jan 05, 2014 | Televison & Video
Tip
SAMSUNG PLASMA POWER SUPPLY CLICKING.
If you have a Samsung Plasma PS50A550 which will keep clicking and not come on, the fault is in the power supply .Check Power supply if its a BN44_00222a. This PCB cost almost $ 300.00 can be fixed for around $ 30.
The fault is in the 5.3v supply to the T.Con PCB. On the Power supply check voltages.VS will not come on unless the T.Con pcb is active.
Check on printed circuit side of PCB on secondary side there are 3 IC close to one another. 2 IC'S are 8 pin and one is 16 pin. Replace both 8 pin reg IC (25h3ll ) these are available from RS components. Part number is STS25NH3LL. The 16 Pin IC is a L6725A but this is not faulty.
lets keep these good TV working for another 4 years.
on May 30, 2014 | Samsung PS50A550 50" Full HD Plasma TV
Blown IC?
Just google ASUS EEE PC 1215N Laptop DC Power Jack Connector, a lot of vendors sell these separately.
Jun 02, 2013 | ASUS Eee 1215N-PU17-SL Notebook
I need sheme for YPLM-M003B of LG L1717S-SN.IC in primar of power supply is burned.
I have this power board,LAF0001 pwm is the only use IC.
20 pin Inverter IC labeled (0zl68GN VKo257 5T 0647B1)
and 2 8 pin dip IC
Sep 10, 2011 | Televison & Video
Error Code 2-2. (Low Voltage Supply) What now?
That is a power supply issue and this requires a skilled person to do it.Trouble shooting in this kind of problem includes voltage measurement and resistance reading of the components/parts inside the high voltage section This is not a DIY problem but if you still want to do it yourself then I can give you some guide that you can try.
1.Check the power supply board,this board is where the power cord is connected.The common problem on this circuit are the filter capacitors .A leak and shorted capacitors always cause that kind of problem the worse is dead set.To visually identify a defective capacitor is their appearance they look to be bulging on top blown,theirs a liquid leak on the body.replace the defective capacitor if you found any.with the same rating and value..
2.Resistors -change value resistors and open resistance can cause the same problem this resistors usually near the regulator transistor.They appears as burned and overheated replace it with the same rating there is an available color code calculator of resistor in the internet click this link and key in the color of the resistor to get the value..
3. check the voltage regulator transistor if it is shorted .the first pin and second pin must not have a reverse reading..
4.Check also the two big IC marked with STK xxxx this IC are the convergence IC it controls the horizontal pin of picture..when this IC are defective this will shut down the power supply ..
The steps I mentioned must be done with a skilled personnel If you feel you can do it,well you can try or better yet bring it to the service center or call a service technician...click this link for service center
good luck hope this helps!
Feb 06, 2011 | Mitsubishi VS-60705 60" Rear Projection...
DPS-210EP-2 power supply blew up
hi there the 8 pin ic in question is a Viper22a available from good electronic stores i got mine from
Cricklewood electronics for a couple of quid , also replace the capacitor c72 47uf
hope this helped
my board is DPS-210EP B REV 00
should be same
Jun 12, 2009 | Westinghouse LTV-32w3 HD Television
Durabrand DBDVR01 dvd/video recorder combi
durabrand model dbdvr01 power supply problem. r106 open circuit,q101 short circuit,d102 short circuit,ic101 blown up,suspect r108a and r100a faulty. ROY
Apr 25, 2008 | Televison & Video
54 people viewed this question
 Grubhead
Grubhead
