Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Sleep timer? No longer have original remote. How do I set the sleep timer manually? from the tv?
  • 10,594 Answers
Sleep Timer option is available in remote only.
Posted on Aug 10, 2008
Emerson lc407em1 sleep timer without remote
Without its remote control, you can't set the sleep timer. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Mar 16, 2014 | Emerson Used Original LC407EM1 Remote...
Need original remote control & owner's manual for GE XS Stereo Commercial Skip TV, Model #27GT616
To get its original remote control and user manual, you have to contact the nearest authorized service center for GE
Sep 01, 2012 | Televison & Video
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Since changing to freeview in april i no longer need the use of the original tv remote as the new remote is being used. my problem now is i cant find how to set the tv to sleep mode shud i fall asleep...
Your new FreeView remote will only support the essential functions of your tv. In some cases that's limited to volume up and down, sound mute and on/off only, but often they can do more. Sleep timers are rarely supported.
Your fix is to either set the sleep timer on the old remote, or to buy another fully programmable learning remote control, where you can customise almost every button and use your old remote to teach the learning version its tricks.
Jul 22, 2011 | Televison & Video
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
This TV has a sleep mode
There are two ways to solve this, but both will require using the original remote for the Magnavox. The original remote has a SLEEP button - press it until the screen says Sleep DISABLED or Sleep OFF.
Or make sure the TV is in TV mode, and Press Menu --> TV Steup --> Sleep Timer --> change to DISABLED
-Tha Mp3 Doctor
Feb 20, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
704 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
