Question about Hoover Vacuums
My fan belt on my hoover is broken,where is it located and how do i fit a new fan belt
  • 3 Answers
I figured out on my hoover upright that many of those models don't access the belt by removing the plate under the vacume. the housing top actually prys off (with the help of a flathead screwdriver). step on the handle release button and lay the handle down first so you have a little room to work with. good luck
Posted on Aug 19, 2008
    President:
  • 1,673 Answers
Get a new belt, then remove the bottom plate. The belt goes around the brush roll and the motor shaft. If you don't see the motor shaft, then you will need to remove the top cover to get to it. The belt will stretch to go from the motor shaft to where the brush roll sits in. If this model has 2 belts, then the drive belt(flat) goes from the motor shaft to the bigger pulley close to the brush roll.
Posted on Aug 10, 2008
Hi, I just replaced my belt for my Hoover Upright Futura with replacement belt 38528040. Now it is making a very loud noise with a lot of vibration. What would be the cause? Could it be the new belt? It...
It is not likely to be a belt problem. I would remove the belt and brush assembly, turn the vacuum on, and see if it is still loud. If it is, the motor fan is broken and will need replacement. If it sounds normal, the problem is in the brush assembly. Examine the ends of the brush for damage or play in the bearings. The brush may need replacement ( part # 48414081 )
Jul 26, 2011 | Hoover U5227-930 Elite Upright Vacuum
The belt is broken on our Hoover Allergen Filtration Model U5018-900 120 v. 60 Hz 12.0 A. Belt 38528040. Where can I get the belt and instructions on how to replace the broken belt?
The owner's manual can be downloaded here (in red, "Download the Instruction Manual (PDF))
http://www.hoover.com/product.aspx?model=U5018900&ds=false
Instructions for replacing the belt are on page 9.
You can order the belt here:
http://www.hoover.com/shop/searchresults.aspx?itemid=221224
Or use the "Retail Locator" on the first site.. Just type in your zip code, and a store that carries Hoover and products near you will be shown.
Oct 07, 2010 | Hoover U5018-900 Bagged Upright Vacuum
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
How to change belt on Hoover DM6227T
Hi Diane
There are two options here; Go to the Hoover UK website and download the user manual (http://service.hoover.co.uk/manuals/Manuals.aspx?Section=6) and add in the DM6227 code and number without the T letter. The pdf downloadable (and free) user manual will upload to your computer.
Or follow this method:
There are two rear screws on the top of the hood of which you'll have to swing the handle all the way down to reveal both screws at the back of the top hood. Undo these screws and put them in a safe place. Then gently prise off the main control selector height dial and the top hood should be able to pop off easily. Then you'll main roller brush should be revealed as well as the broken belt.
Once the belt is removed, clean the brush roll of any threads or hairs that have stuck the bristles down. Then fit new belt, align the roller bar properly including the new drive belt and then refit the top hood back on, snap fitting down, two screws in and gently refit the control dial height adjuster back on making sure the front raised part of the dial knob is facing the Hoover.
Anything else don't hesitate to contact.
Nov 13, 2009 | Vacuums
Hoover model u5146900 the belt drive is bare metal wears out the belt quickly is there a part that fits over the pin?
The belt drive shaft does not actually wear out the belt unless it has a burr on it, however frequent use does.It should be kept clean and polished with no residual dirt ir burnd rubber.
On a department store brand vac you should expect to change the belt every 3 months, broken or not as it stretches under normal use for best results. Remove and clean the end caps on this unit for longer belt life and use only genuine Hoover belts with matching part #.
For longer wear and tear, next time around consider a vac with a fibre embedded gear belt similar to the fan belt on your car.
A belt of this nature gives 100% performance at all times and therefore keeps yopur carpets much cleaner.
Nov 01, 2009 | Hoover U5144900 / U5146900 / U5147900...
Bearing screeching?
Yes, it could be a motor bearing. Another possibility is the fan could be broken. Remove the bottom plate from vacuum. Spin the belt motor pulley slowly and view the fan. You may have a plastic fan that has broken or something is keeping the fan from spinning. Here are links with illustrations to an online guide. (the links will say "belts" but it will show how to get to the fan). Click the one that best matches your vacuum.
Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Aug 21, 2009 | Kirby G6 Bagged Upright Vacuum
Hoover f5915
Since the Steam Vac does not have any belts... the logical issue is Switch setting (Hi, Low, Off) on the base cover. The only other is dirt collection on the air intake for the brushes (unit uses air passing over plastic fan blades to spin the brushes). To clear the dirt problem, remove the clear plastic cover located just in front of the brush Switch. You can now use your finger nail (or an old tooth brush) to clean the filter screen located just below the Switch. Don't tear it, just gently remove the accumulated dust/hair.
Brushes should spin once you reassemble and power it up!!
Aug 14, 2009 | Hoover F5906-900 Upright Steam Vacuum
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Trying to fix new belt to Hoover Turbo Power vacuum cleaner. Don't see how the belt becomes taut. Fitting it around the roller, there is nowhere to fit the belt to, it just sits loose.
I looked at the user instructions guide online and saw where the 'other end' of the belt should be fitted. It was extremely hard to fit but eventually managed it. Thanks for this solution site. I wouldn't hesitate to use it again.
Feb 17, 2009 | Hoover U5396-900 Turbo Power Vacuum
LOUD noise
The armiter or fan is broken and if you get it replased it should work like new
Jul 24, 2008 | Hoover U5227-930 Elite Upright Vacuum
Vacuums Logo
89 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
