Question about Toshiba Satellite P205-S6287 Notebook PC
Help How to sort pxe-e61 and pxe-mof error codes
    Scholar:
  • 46 Answers
What the error is teller you is that it's not seeing any cable like from a network for example being plug in.
One thing you should have done is check to see if your hard drive is spinning. No spinning, No windows.
Those errors you see is because under the bios, in the boot priority order, the floppy and the hard drive are not responding. Also, if you OK in taking apart your laptop, just check the connectors from the hard drive to the mainboard. Make sure they are push in all the way in. No pins are damage or bent. Those can cause the hard drive not to be detected by the bios.
Let me know
comier957
Posted on Aug 10, 2008
Error message on dv 1000 pxe-mof and pxe-e61
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | HP Pavilion dv1000 Notebook
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
WHEN I CUT ON MY LAPTOP..AFTER REINSTALLING WINDOWS XP.. ERROR ERROR FOR.. RELTEK RTL8139X/8130/10X PCI FAST ETHERNET CONTROLLER V2.13 020326 PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING...
the system is trying to boot to the Network adapter. If the system boots into Windows after the error, then all you need to do is change the boot sequence in the BIOS (Resetting defaults will likely fix this)
If system is not booting into windows after the error then you may have a hard drive fault
Sep 09, 2010 | Computers & Internet
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
From the first time I try to start my new lenovo 3000 g530 4446 3fg it tells me pxe-e61 media test failure check cable, pxe-mof: exiting broadcom pxe rom and I made the laptop boot from the hdd but it gave...
The PXE-E61 error is caused by either a faulty disk controller or most likely a faulty hard disk. Because the Lenovo is new I suggest you return it to the supplier to get it fixed under warranty.
Do not try to fix it yourself because you can void your warranty.
Sep 27, 2009 | IBM Computers & Internet
Toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
Jun 16, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Toshiba Satellite P205-S6287 Notebook PC Logo
248 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
