Question about Dishwashers
Simpson dishwasher intermitantly does not wash properly, i think it doesnt always fill correctly
  • 20 Answers
Make sure the filters are clean and that the spray arms do not have food particles blocking the outlet holes. Always a good idea to rinse these off plates before they go into the dishwasher.
Posted on Dec 23, 2010
SOURCE:
Recently had a leak in our water pipe between mains and house.We had the pipe replaced.Then the washing machine wouldn't fill so we replaced solenoid valve-it works now. The dishwasher won't fill now
when the pipe was repaired , there is every possibility that dirt got into the pipe and will affect all solenoid operations and taps
remove all hoses and flush the pipe out well
Oct 21, 2016 | Simpson Washing Machines
Recently had leak in water between mains and house. Pipe replaced.Then washing machine wouldn't fill.Replaced solenoid valve -works now.The dishwasher Simpson EZISET 52B850WJ*03 won't fill.Same?
Could be dirt in the water lines after you repaired. You should always run your taps for a while before running machines that use water. I like to run water from my out side taps if I have outside repairs.
Oct 21, 2016 | Dishwashers
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Gday,ive got a simpson eziset 950 top load washing machine,it does the first wash sequence and pumps out,but the pump keeps pumping even though its empty and it wont go any further,wont re fill or spin,and...
This is a seriously wild stab in the dark at your problem. Washers usually have a totally jacked-up schematic somewhere in them. I never can figure them out.
But, I think your fill switch is stuck. The ones I've worked on use a type of pressure switch where water rises in a tube and makes the switch.
Find the switch and see what it is doing. The washer thinks water is still in the tub because the switch is telling it so.
Clean the lint trap also.
Our KenMore washer also automatically selects warm and it ain't broke.
Sep 16, 2017 | Dishwashers
I have a GE profile dishwasher that is about 5 years old. The problem I am having with it is that it just doesnt clean the dishes. The soap sometimes doesnt alway disolve. the water is the correct temp....
Start the cycle, then after it fills with water, open the door. Move the wash arms so they all point directly to the front and put a mark on the ends with a magic marker. Close the door and let it run 10 seconds or so, and re-open the door. If any of the wash arms did not move, clean out the holes in the wash arms (seeds, candy wrappers, twist ties, bones, broken glass, etc.). You may also need to clean out the screen at the pump inlet, but usually the spray arm holes are the problem.
Sep 17, 2009 | Dishwashers
Dishwasher slowly fills up with water after wash cycle completed
Inside the bottom of the dishwasher under the lower rack to the side there is a float that regulates water level. jiggle it up and down a few times , it will be OK. Vitally
May 12, 2009 | Dishwashers
Water not emptying in dishwasher model simpson silencio 850
How long does it take to wash dishes completely in a ASimpson dishwasher
Apr 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
182 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
