Question about Electrical Supplies
Ryobi lawn hornet mk2
Recived this brush cutter for nothing when I bought a lawn mower of the owner. Has not used it for a while. Put fuel in, will just start and just idle. Took air cleaner cover of, and ajusted a screw marked L and H. I take it this is a lean and rich mixture screw? Screwed right around to H. will idle very high, but as soon as you touch the throtle, it dies. Sounds like a fuel problem? Any suggestions?
Change your spark plug
If the fuel oil mixture is too oily it will foul the spark plug and no cleaning will get it right.
If there is a lot of oil in the crankcase it may foul the new spark plug so another new one is needed
Posted on Sep 28, 2008
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Arbor stuck on gear head/bc26
I have the same problem. Any solution?
Apr 20, 2010 | Ryobi Garden
Hi, I tried to start my ryobi scrub hornet and found that all the fuel lines have disintegrated and likewise the primer bulb. So I bought those parts and tried installing the fuel lines. Not knowing how...
The primer bulb is attached to the carburetor by a flange with 2 screws...the "center" port goes inside the carb. The upper port on the carburetor is a return line to the gas tank. The lower port is where the supply line is connected - this line goes into the tank and has a filter attached to the end.
I hope this helps you. Please let me know if it does or doesn't.
Dec 16, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi Electric Lawn Hornet Model RLT800QF. Need
I went to www.ryobipower.co.uk, I was ynable to find a lawn hornet on the website. But you may have better luck because in the states we do not have lawn hornets.
Good Day Mate
Dec 14, 2009 | Garden
Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Nov 30, 2009 | Ryobi Garden
Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Apr 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Fuel ratio for Ryobi lawn hornet mk 2
25 to 1 = 200ml of 2st oil to 5 lt ulp
OR I use 150 ml "stihl" 2st oil to 5 litre of ulp Less smoke and better oil.
Jan 12, 2009 | Garden
Can't remember what fuel our Ryobi Lawn Hornet uses
All 2 cycle tools must have oil mixed with the gas. Use the proper oil and mixture recommend by the manufacture.
Dec 08, 2008 | Ryobi 15" Electric Factory Reconditioned...
Electrical Supplies Logo
331 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
