Question about Sony Cyber-Shot DSC-F707 Digital Camera
DSC F707 Error C:13:01
I bought a 4 GB memory stick Pro Duo and when I insert it in the slot it give me "Memory Stick Error C:13:01".
  • 2 more comments
  • vankampen Aug 27, 2008
    I have tried memory cards from 16MB-128MB, and they all get the same error number. They worked before on the camera- I am trying to get the pictures off of them!
  • mpeltzer Dec 02, 2008
    I have the same issue. I tried several memory cards, same issue. It started off with klugy errors when I used the camera. Then I got the kiss of death Error C:13:01. Now I can't use it at all.
  • Anonymous Mar 25, 2009
    i just purchased a 1gb memory stick PRO, it gives me the c:13:01 flashing across the screen with memory stick error. everything looks the same, except the PRO.
  • Anonymous Apr 23, 2009
    Sony DSC-F707 no large memory card compatibility.
Can't use Memory Stick PRO's on the DSC 707, they won't format. The technology of the PRO's postdates the 707's.
Posted on Mar 09, 2009
we had the same problem and found a solution on this website:
http://batteringram.org/misc/f707repair/
Posted on Nov 22, 2009
  • 157 Answers
Try one of the following methods
1- While the memory card is in the camera, shake the camera and try and take a picture
2- Format the memory card in a pc or laptop (a sony vaio if u have one)
3- Insert the memory card like 10 - 20 times rapidly in-out
4- Format the memory card while inside the camera (option to format card is in the menu)
Hope this helps
Cheers
JigSaw
XoXo
Posted on Aug 10, 2008
Cable inside camera for memorystick housing needs to be cleaned and reseated
Posted on Oct 28, 2008
If you really have a F707, it won't work with anything over 128MB according to this chart.
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCF707#m1
Posted on Aug 11, 2008
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Memory Stick error
Hello!
Following types of memory sticks are compatible with the Camera model DSC-V1:
Memory stick: 32/64/128 MB
Memory stick Pro: 256 MB/512 MB/1 GB/2 GB.
Mark 2 Memory stick Pro: 1/2 GB.
However, in order to use Memory Stick Duo or MagicGate Memory Stick Duo media with the Camera, a dedicated adapter (MSAC-M2) must be attached.
Follow the steps given below to troubleshoot the Camera that is not recognizing any compatible memory sticks:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Furthermore, you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds.
If the issue persists even after performing all the above mentioned steps then the Camera is required to be diagnosed and serviced.
Aug 22, 2009 | Sony Cameras
Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Error Viewing pix
Do not use a Memory Stick Pro Duo - High Speed , use a Memory Stick Pro Duo below 2 GB
Apr 16, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
File error
I was having the same problem with my 4GB memory stick pro duo, when i took more than 50 pictures with my camera (dsc-w90) i would get the blue screen with the file error message. I'm guessing you bought the memory stick on ebay right? I bought mines there and it turns out it's a fake one. If you also bought it there then you most likely have a fake memory stick because I found out that most of the memory sticks sold on ebay are fake, to help you figure out if you have a fake one or not check out this guide or google fake memory stick pro duo. http://reviews.ebay.com/FAKE-Sony-Memory-Stick-Pro-Duo-MagicGate-Cards-Exposed_W0QQugidZ10000000001236041
Dec 25, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
F707 type of memory stick?
I bought a Lexar 256MB, since the F707 can't use PRO or anything about 128mb, it has two 128mb on one stick. There's a switch on the stick to change it when the first 128mb is full.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Memory stick problem
I had this same problem and the procedure it the following : IF YOU WANT TO SEE YOUR PICTURES, DOWNLOAD "PhotoRescue" INSERT YOUR MEMORY STICK CARD IN YOUR CAMERA, RUN THE SETUP1 AND FORMAT IT. Good luck
Sony Cyber-Shot DSC-F707 Digital Camera Logo
1,286 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
