Question about Nokia 6131 Cellular Phone
Nokia 6131 wont switch on
I have a nokia 6131. Have had it for 2 years without any problems and it had good talk time so no indication of bad battery. I got a 'charger not supported' message when I tried to charge it recently. My husband uses the same charger to charge his nokia and had no message error. After the 'charger not supported' message the phone cut out on a call and then I got a 'test mode' message. The phone switched off. It woulod not charge. We cleaned the terminals and got it to charge again, but now it will not switcth on. I can see no reason why this has happened as I take great care of the phone. Can anyone please help me? I need to get numbers out of this phone urgently.
  • Nokia Master
  • 1,800 Answers
The phone need to be flashed take it to agsm service store and tell them to read the user area for reaching ur cantacts okay ??
rate me
Posted on Aug 16, 2008
SOURCE:
My nokia 6131 is fulled down and turn off and now is not turn on.....what is wrong whit it and waht to do....:(
Remove the battery, than just blow a gentle hot air to the back side of the mobile(motherboard). Ensure that it does not over heat. when the whole board is little warm. wait for some time and then put the battery in and turn on.
Nov 23, 2013 | Nokia 6131 Cellular Phone
Not chraging or no charge battery indicator moving
Either the charger is bad, or the jack where the charger plugs in is bad...
See if you can find a friend that has the same phone so you and try their charger...if another charger does not work then the phone will need to be repaired...
heatman101
Jun 28, 2011 | Nokia 6131 Cellular Phone
How can i reformat my nokia n-gage
dial * 7370# and *7780# one after other every time phone ask for security code and restars and formts it self . if u dont know the security code switch off hte phone hold *,3 and green dial key togetehr and switch on the phone without relesing it for 15 sec even after power on . then phone will start formatting care full battery must be fullly chrged
Jun 11, 2009 | Nokia 6131 Cellular Phone
Nokia 6131 date/time wont keep going when phone turned off
Going further in my investigations, I have realized that the problem did not occur when my phone remained plugged via the charger. That made me think that there might be a problem due to a weak battery. I have bought a new battery BL-4C two days ago and the problem ..... disappeared !!!
Nov 20, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 Case Replacement
Could u say where u got ur panel for nokia 6131.. im badly in need of phone
Aug 23, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 security code
Default code for Nokias is 12345. This will work if you did not change access code.
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager
check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 6300.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
Jul 12, 2008 | Nokia 6131 Cellular Phone
NOKIA 6131 PROBLEM
Hi go to ur mobiles setting and select full fectory default its security code is 12345. thanks keep voting.
Apr 04, 2008 | Nokia 6131 Cellular Phone
Nokia 6131
open ur phone menu. go to settings options,scroll it down further and look for display settings. in display settings there will be option to adjust its brightness.
Feb 22, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 Cellular Phone Logo
251 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
