Monitor screen froze & displayed jumbled colours. PC won't boot up now - screen disolayed is distored & then goes blank. PC won't then power down using on/off button on base unit.
    Scholar:
  • 46 Answers
Your video cards is the issue. To be sure, if you have another video with the same connector (PCI, AGP, or PCI-E Slot) try a different card. If they are ok, then you know. If not, then I'll would look for a port tester for that graphics slot. I've seen Port tester for PCI. I'm not sure about the others. Can't hurt to look.
Let me know
comier957
Posted on Aug 10, 2008
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
LCD is on...seems like backlight is not functional; when external monitor connected, boot-up and bios screen visible. After boot-up, screen goes to "power save" mode and will not return
Use the 'FN' key (blue coloured?) and one of the other blue-coloured keys to "toggle" the video:
1. LCD only
2. external monitor only
3. both LCD & external
After boot-up, Windows defaults to "LCD only", and so the external monitor goes to "sleep".
Dec 11, 2009 | Acer TravelMate 4010 Notebook
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Philips x57 distored / flikering screen
The problem is the pathway from the chip to the internal display. The Nvida chip has several output lines, many of which go to the external monitor but many also go to the internal display connector. I had a case recently where the screen worked fine until the customer opened the display past 90 degrees. What was actually happening was that enough presure was being applied by the internal connector to lift the mother board connector off the mother board. Apparently the factory solder job wasn't too good. We were lucky in that we used a high intensity heat source which remelted the solder on the connector. Whoever was dilligent enough to be to test your screen and cable should be able to trace the signal from the chip out.
Mar 23, 2009 | Computers & Internet
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
