Question about Fantom Drives 120 GB Hard Drive
USB drive was workign fine, now USB malfunction
My Fanton 160 GB external USB drive was working fine and then it disappeared. I powered it off and plugged it back in. Now I get an error message from Windows when I plug it in ... USB device has malfunctioned and cannot be recognized.
  • chakkilam Aug 28, 2008
    I can see the blue light but i cant find the drive connected to my machine.
  • 6,831 Answers
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Posted on Sep 29, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ... > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
My seagate device driver is not installing plz help me
1. Download and install "USB Disk Ejector beta 4"
2. Switch PC off.
3 . Connect seagate
4. Power PC on and press F8 while windows booting up
5. Enter just "Safe Mode"
6. when powered up, run "USB disk ejector" and your drive should be displayed. Eject the disk, once it disappears of the list unplug the USB cable and wait for the LED to go off the drive. Then replug the drive back in and wait until "USB disk ejector"recognises the drive and repeat this step a few times 3/4 times then eject and reboot PC in Normal mode.
May 11, 2012 | Seagate 320GB Portable External Drive ...
Blinking not mounting?
if you are a front usb port on your desktop , switch to rear one. or try it on different pc, if aproblem continue that means that the usb controller on your external HDD is malfunctioning , you should have it fixed or replaced with exact same one
Feb 08, 2012 | LaCie External USB 2.0 500GB 7200 RPM 500...
Windows 7 states external drive 'malfunctioning'
you got two possiable issues here.
1. The ac apadtor not suppling enough power to the hard drive.
2. The USB controller insdie is faulty.
I have a solution for you. Take the hard drive out of the unit (if you care about your data)
1. put it into another external case witch are sold for under $15.00 at or simply plug it into your desktop inside vai your SATA controller. If you have a laptop of course that will not work you need to then purchase a external enclosure.
Click HERE for my tip and video on how to get your SATA drive out of its case.
We work for your ratings so please before you leave the site be sure to leave you feedback and ratings today.
Jul 01, 2010 | Western Digital My Book Essential Edition...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
SmartDisk Crossfire Desktop Drive
Usually this is a problem with the usb port not being able to supply enough power to the drive. Often, units like this will come with two usb plugs on one cable to increase the current supplied to the drive. If the drive has an input for external power (some do, some don't), then using external power would help.
Apr 23, 2008 | SmartDisk Crossfire Desktop (xf160f) 160...
Fantom Drives 120 GB Hard Drive Logo
75 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
