Your scope may not be hurt if water has not caused any rust yet. Things you will need, (1) hair drier, (2) Vaseline, (3) large clear plastic bag, (4) gas from a paint ball gun canister or similar type of inert gas you can use. Remove the eye piece, and shake as much water out as you can. Use the hair drier and heat the tube up, not too hot but warm, to dry the inside as good as you can, keep after it, shaking it and heating it. Once you feel all the water and moister are gone. Put a good amount of vaseline on the threads of the eye piece. The put the scope, the eye piece in the plastic bag. Use the paint ball gas and inflate the plastic bag, tie off the bag leaving room so you can screw the eye piece back on the main tube. Leave the scope in the bag for a few minutes before you do screw the eye piece on letting the gas fully get in the tube. The gas will give a bit of positive pressure inside the tube, Will displace any other air that will have moister in it. Keep the inside from fogging back up. The vaseline will help seal the gas inside. Hope this Helps Fix Ya up.
