Band of light at top and bottom of brand new LCD TV screen
  • 80 Answers
SOURCE: Red band at the top of tv screen?
Your optical block is going bad. Contact sony support. They will sometimes warranty these even after the 1yr warrany has expired.
Posted on May 21, 2009
  • 8 Answers
SOURCE: Blue Bands on sides of Zenith Projection TV D60WLCD
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Posted on Aug 02, 2009
  • 94 Answers
SOURCE: Brownish band across top of screen
Please press the WIDE button on the remote repeatedly to remote the Bands. If the issue persists, you may need to change the Aspect ratio to 4:3 on the Video source that you have connected to the TV. Check the link for more info:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C308757&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=130649210&stateId=0%200%20130647809
Posted on Sep 22, 2009
SD Tech
  • 14553 Answers
SOURCE: we have a Sony wide screen projection tv model
It sounds like a convergence problem--If you go into the customer menu and select convergence--if colors are bowed and or will not adjust:
The two STK-392-560 CONVERGENCE IC's that this set uses need to be replaced--their location numbers are IC8001 & IC8002.
They are located on two metal heat sinks with fins--and are black in color--2 1/2 inches wide by 1 1/2 inches tall and will have the full STK number printed on them in white.
Usually just both chips need to be replaced but there are some special fuses and resistors that protect them. A pair of the chips can be purchased on Ebay for about 12 dollars plus shipping.
The chips fail because a white grease to transfer heat from the metal back of each chip to the heat sink dries out and one or both overheat and fail.
If you or someone you know can do this repair you can save the set and a lot of money---most shops are going to get 300 or more for this type of repair.
These sets are dependable and other than this do not have many serious problems.
If you get someone to do the repair make sure BOTH chips are replaced or you will have the same problem again in a few months---lifespan of these parts is 5-8 years.
Let me know if you have questions or need advice--I am here to help people.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 06, 2009
Ecollier2012
  • 3459 Answers
SOURCE: my tv has a color
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jan 28, 2011
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
Whire vertical band , 3 inches wide with red kine in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
White band from top yo bottom of screen
Good luck with this. If it is under warranty, Sharp will take forever to do anything about it. I had this issue and Sharp wanted pictures of the problem, Pictures of the serial and model number and the receipt. I sent it to them 6 months ago and never heard anything back. If it is not under warranty, this is a major repair and it may cost more than a new television.
Apr 11, 2014 | Sharp LC60E88UN 60 in. LCD TV
Why is there a grey band on my new tv
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Feb 07, 2014 | Vizio SV470M LCD TV
My new lg 3d tv is closng on top bottom and sides is there anything i can do to cure the problem
Could you provide more information? What do you mean when you say, "closing?" Do you mean there is a black band around the picture? If so that means the original picture is recorded at a lower pixel density than your TV will display.
In the past most TV program signals provided a picture dimensions (in computer standards) very roughly 600 pixels wide by 400 pixels tall. What this means is that a picture of that pixel size will display as a small, squarish image slightly wider than it is tall on a (now) standard 1080p LCD television--which produces an image 1920 pixels wide by 1080 pixels high.
That would be nearly unwatchable (picture too small) except for the fact that most TVs compensate for the relatively small size of "standard definition TV (SD TV, as opposed to HDTV) by enlarging the image so that the top and bottom edges of the picture touch the top and bottom of the TV screen. This will leave black bands on either side of the picture. Some LCD TVs will automatically stretch BOTH dimensions of the image, which yields a distorted, "sqaushed" image.
All my comments above apply to both standard LCD and 3D-LCD TVs, by the way.
A more precise overview of the facts about TV picture size can be found here:
http://en.wikipedia.org/wiki/Display_resolution
Nov 23, 2013 | LG 42LW5300 42 Class 3D LED HDTV
Tonight my boy friend accidentally knocked over the tv. the bottom metal base came off and there are multiple bands of horizontally in different colors that keep coming up on the picture. You can see the...
Sorry this tv have damages cracks on the LCD screen panel already.Tv have to replace the whole LCD screen panel to repair it.As the LCD screen panel are 90% important to the tv and very limited in production.Buy and replaced only by the tvs corporations only,cost the same as a new tv.This tv now not worth as a whole tv anymore,all these tvs in this situation alway end up as salvages tvs as for spare electronic PCB boards for other tvs only.Time to buy a new tv make the boy friend pay some money too,because he cause the accident.
Jun 05, 2011 | Vizio VS420LF1A TV
My dell P2210t will only light up the top half of
it may be better to bring your LCD to where you bought to claim the warranty. don't try to open the LCD and try to fix it because you will lose the warranty.
Oct 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
1" Band from top to bottom
you need a new panel get it fixed now before it gets really expensive. call up the manufacture to see if they have an out of warranty service or replacement for your tv...
Oct 25, 2008 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
