Samsung SyncMaster 2233BW 22" LCD Monitor Logo
Posted on Apr 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Windows 7 Home Premium Dell Desktop displays upside down on my Samsungn SyncMaster 2494LW monitor
Anonymous
Level 2:
Sergeant:
  • Expert 183 Answers
  • Posted on Apr 25, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
183
Questions
0
Helped
26258
Points
525
Welcome to fix ya
Here is once simple step you can try.
press CTRL+SHIFT+ directional arrow up ( note that you can also press left or right on the directional keys to change orentation)
this is the commond shoftcut for screen orentation
hope this helps and please don forget to rate if this solves your problem
2helpful
The monitor is a Samsung SyncMaster 191T. My cat laid down on the keyboard today and now I am looking at an upside down screen. Can you help me out?
If you are in Windows XP, you can use the following key combination:
CRTL + ALT + up arrow
I am not sure if this combination works in Windows 7.
Good luck.
Dark screen/video card problem on dell desktop
If you have an optional video card installed in your system, try plugging in the the monitor using the 15 pin VGA plug on the back of the computer and see if you get the same results. There might be a plastic cap covering the VGA plug so you'll have to remove it for testing purposes. If no change then try using a different monitor. You can also try plugging the monitor into a different computer.
If the monitor display is normal using the VGA port then your graphics card has a problem. If the monitor is still dark attached to a different computer then your monitor or monitor cable is bad.
I have a strange problem. Using Windows 7 and Nvidia 260 GTX video card. I have a 20" Samsung syncmaster & a 32" Samsung LCD TV 1080p. I want the Syncmaster to be Monitor 1 & the LCD to...
Windows 7 has some neat little enhancements, one of them being how it lets you handle dual monitors. If you're adding a second monitor to your Windows 7 home or office PC, which is a very good idea, it's a breeze to configure.
There are actually two ways you can currently setup multiple monitors in Windows 7, either by using a keyboard shortcut or via the traditional system properties.
I really like the first method since it's new and is way easier than having to go into the Control Panel or anything else.
Simply press the Windows key and P (Windows + P) to bring up a quick menu of options.
Pretty neat! You can pick to show only the computer, make the second monitor a duplicate of the first, extend the desktop to the second monitor or turn off the first monitor and activate the second.
The second way is to right-click on the desktop and choose Screen resolution.
Now you'll see the familiar 1 and 2 to distinguish which monitor is which. There are several options and under Multiple Displays, you can choose from the same options as when you pressed Win + P.
That's it! You can also change the orientation of the displays and change the resolution of each display. It's pretty straight-forward in Windows 7 and a lot easier! Enjoy!
3helpful
Image on Dell 4700 Monitor has rotated 180 degrees
This should be a very fast fix.
First try pushing the Shift and Home key at the same time.
If that didn't do it,
Right click on the desktop,Click graphic properties,Click display settings,Uncheck the box "Enable rotation" and click ok.
5helpful
My DELL Monitor shows the picture upside down
Try holding down the CTRL key + ALT key and tap on the Up arrow key once to rotate the display back to orginal orientation
Thanks
proton
38helpful
2answers
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
14helpful
2answers
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
