Question about Gaggenau VK 230 Rice Cooker
Gaggenau vk230 steamer doesn't work
I have taken this steamer back to gaggenau about 5 times and they say it works. Each time they bring it back to my place and install it it works first time but when they leave and I want to start it up the boiler just doesn't kick in. The other day my wife brushed against the temperature knob and it worked but hasn't since. This is a really weird problem that I can't figure out. Please help it's been a year now I have had this very expensive steamer that I can't use.
Are you sure the child lock feature is not preventing it from working? Exactly what is the problem? Is the display blank? Is the problem that it just won't heat? Are there any error codes in the display?
I also have a VK230 that is having problems and am gaining experience with troubleshooting this steamer. Gaggenau is very difficult to work with and it is difficult to find a service company that is knowledgeable about the brand.
Are you interested in selling yours? Parts from yours may help me fix mine.
Posted on Jun 30, 2009
SOURCE:
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
I have the EAM3200 coffee maker and it seems to be leaking somwhere into the front and back of the drip tray and produces only half a cup of coffee - rest of teh water goes in the drip tray seems to be...
I have the same issue. I have tried replacing the O-rings in the water heating element and the steamer, and it still does this. For a temporary fix, try running the steamer for about 30 seconds, or until it is running "full steam", and immediately make your coffee. This has worked for my machine for the last 4 months. It is used about 5-10 times a day at my work, and this still is working. I believe the issues is it is losing pressure somewhere, and the water cannot travel through the infuser. I have taken apart my machine more than 10 times, and I still cannot find out where the pressure loss is. I know this is a temporary fix, but it will work until something more permanent can be done. Hope this helps!
Feb 12, 2011 | DeLonghi EAM3200 Espresso & Coffee Maker
When my sis wanted to use the rice cooker,a "f2" sign appeared.
I opened the cooker and removed the battery and put it back, it worked. Beware that the battery is glued to the circuit board and has to be taken out carefully. Guess removing the battery made the machine forget its previous state and is now back to cooking.
Jul 11, 2009 | Gaggenau VK 230 Rice Cooker
Gaggenau 230-110 steamer - cant take the child lock off!
Hold the child lock button down for 5 to 10 seconds. This should unlock it.
Apr 09, 2009 | Cooktops
Gaggenau AH 250-760
I repair them in nyc all the time. unit will work for years after repairs. 1-888-nyc-1055
Jan 27, 2009 | Gaggenau AH 900-761 Kitchen Hood
Steam frother
1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for the machine for an hour. 4. Remove sheath from the steamer. 5. Place tip of steamer into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through steamer.
Optional: Before starting the process, unbend a paperclip or metal hook (for hanging holiday ornaments) and use it to clear the steamer orifice.
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Jun 19, 2008 | Krups Allegro FND111 Espresso & Coffee...
Priming
turn on the coffee and let out the steam at the same time it will bring the pressure to the coffee the shut of the steamer.
May 08, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Door locked after power surge/failure
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
Jan 06, 2008 | Gaggenau EB270 Electric Single Oven
Gaggenau VK 230 Rice Cooker Logo
797 people viewed this question
Top Gaggenau Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Gaggenau Kitchen Appliances - Other Expert? Answer questions, earn points and help others
