Question about Brother Office Equipment & Supplies
Dcp-135c printer keeps printing pages not requested. it will print the ammount but not actual pages. it has already printed the pages it now prints but that was part of a previous request. i have been printing ammounts of approx 30 of a87page document. it printed a batch to 67 but now insists on returning to page 60? HELP! darryl
  • 12 more comments
  • darrylh Aug 10, 2008
    tried what was recomended but no change
    problem remains .prevented getting on brother site from australia. this is why i am seeking your expertise !
    how do i clean the head this is only a new machine.?
    i am surprised that this would be a solution but your the boss. waiting to hear how?
    completed your recommendation the initial problem remains
    still no change
    no change
    sorry mate this is the only computer i have. any other thoughts!
    done what you suggested. nothing will print at all now ,but there are apparantly 16 reports waiting which i have no idea how to clear. each time i check action it just adds another job!
    no response. jobs just mounting up.
    java was interupted. can u supply link again. it was pretty slow is that normal-i am on dial up?
    still no success. initial problem remains
    gotta tell you guys for all the effort nothing has changed!
  • darrylh Aug 11, 2008
    Mate, i just about had enough i checked changed confirmed etc etc .
    so i sat down decided that i would have to logically sort this little ****** out. there was nothing more to do to the printer or the pc so it could only be the file. yep,sure as putting ya pants on in the morning. thedocument didnt hasnt been numbered until page 7.thats why we were out of sync.
    well what a huge relief ! do i get some sort of freebie for that, my money back or a slap for not sorting it sooner.
    Novelist:
  • 106 Answers
Uninstalling and reinstalling the printer driver would help solve the issue BUT it would take so long. here are the things that i want you to follow exactly.
1. Click on start, then go to control panel;
2. Inside Control panel menu, look for Printers and faxes (XP OS) or Printers (for Vista OS);
3. Inside printers and faxes/printers, you will see you printer driver with pending documents to be printed;
4. Right CLICK the printer driver, then choose CANCEL ALL DOCUMENTS;
5. Then, press the F5 button on the top most part of your keyboard to refresh the application;
6. If you see still pending documents on the printer driver, cancel all again by right clicking the printer driver and choose cancel all documents;
7. Then, press again the F5 button (3 times) on the top most part of your keyboard to refresh all the applications;
8. CHeck of the printer icon has still pending documents, If none, go to the next step.
9. CLICK on start, then look for RUN program;
10. Inside RUN program box type in the word SERVICES.MSC to access the services menu;
11. Inside services, look for PRINT SPOOLER;
12. Right CLICK PRINT SPOOLER then choose RESTART;
13. After restarting the PRINT SPOOLER, try printing again.
14. That should SOLVE ALL YOUR PROBLEMS..
Please let me know the result following the steps.
adonscott
Posted on Aug 11, 2008
  • 2,071 Answers
If your IP address is different:
Continuing from the steps you followed previously:
  1. Click the Add Port... button.
  2. Select the Standard TCP/IP Port option and click New Port. The
    Welcome to the Add Standard TCP/IP Printer Wizard appears.
  3. Click Next.
  4. In the Printer Name or IP address area enter the node name of the
    Brother device as it is printed on the network configuration page. An
    example node name could be: "BRN_34FDAA".
  5. As you enter the node name, the Port Name box will be automatically updated.
  6. Click the Next button.
  7. Click the Finish button.
  8. Click the Close button on the original Printer Ports screen.
  9. Click the Close button to return to the original properties screen.
  10. Click the Apply button and then the OK button.
  11. Now try to print a test page.
hope this may help;
regards,
VOTIT
Posted on Aug 10, 2008
  • LORETO LACARON
    LORETO LACARON Aug 17, 2008
    did the solutions from all of us experts solved your problem if not
    then let us know the current updates so all the fixya experts can
    assist you further.
  • 477 Answers
Hello
I think you use wrong paper size when you print. try to change this in printer settings. to remove your printer job do this->
right click my computer-> manage->
computer management starts.
click on services and applications->
services and seek for "print spooler" stop the print spooler and unplug the printer. restart the computer and the jobs should be cleared.
  • Filip Eastman Aug 10, 2008
    here is a easier solutions for the job problem
    1. Close all open Printers folders.
    2. Stop the Spooler service. run ->cmd type NET STOP SPOOLER at a command prompt. If you're using TCP/IP Printing Services, you'll need to stop that service as well.
    3. Open the %Winroot%\System32\SpoolPrinters directory (same in both operating systems). Make sure Explorer is set to view hidden and system files.
    4. Delete all *.SPL and *.SHD files in that
      directory that match the time/date stamp of the job you're trying to
      kill. If you're trying to purge everything, delete all files with those
      extensions.
    5. Close the Printers folder and restart the stopped services. You can restart the Spooler from the command line by typing NET START SPOOLER.
    Master:
    Sergeant:
  • 398 Answers
If you are using windows xp you can click on start, then control panel, then double click printers & faxes, and then double click the printer you are using. You will have a box with all the tasks that you sent the printer click on one of them Then click on document, then cancel, and then ok for are you sure. You can delete each of them one at a time. Once you clear this load up, you will probably have better luck finding your real problem.
    Master:
  • 623 Answers
Restart your pc
    Master:
  • 521 Answers
First shut down your pc then on . then cancel all the pending documents . then its done .check whether all the connected wires are firmly connected. before you start your printing again.
  • tech expert12 Aug 11, 2008
    uninstall and install the driver again if you have the proper driver cd and then check.
    Master:
  • 763 Answers
After you install the driver check the wires and the control panel of your printer. it might be the problem. go to control panel and check the add hardware. see if its functioning correctly. hope that helps!
CHARCOIS
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Your print head (the part which actually forms the print is inside the printer) a small amount of ink is used to act as a coolant (in the case of a thermal print head like yours) This prevents the print head from warping or fusing. Clean the print head. it will be OK
thanks
good luck
  • 10,594 Answers
Please Uninstall printers driver and reinstall it. It seems driver of printer is curropted and needs to reinstall it.
Here is printer driver download link, try it and if problem still exist, call the help line of brother-usa.com
  • Shahid Electronics
    Shahid Electronics Aug 10, 2008
    what was the result, bit detailed answer would help to sort out problem.
    Alright, lets try some thing else. Attach this printer with another PC and check its printing results. Its a way to divide the problem and will confirm us printer hardware and printer driver soaftware. I hope this suggestion will helpful.
DCP-135C after inserting new inks message reads "Maintenance and users guide chapter 46 cannot clean" Will not print.
Dec 01, 2010 | Brother Office Equipment & Supplies
Brother DCP-135C won't print yellow
1 years?
Means still under warranty for print head. maybe print head faulty. Better send to Brother.
Jan 27, 2010 | Brother DCP-135C Flatbed Digital MFC...
The colour on my Brother 135C Printer is not printing properley, could it be that the printer heads need aligning? If so how do I do that? Regards, David Melton
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother DCP-135C Flatbed Digital MFC...
DCP 135C won't print in black
This is a generic problem for many printers. Some printers print black by 4 catridges. Try this, or it will be better that you call service support.
Aug 12, 2009 | Office Equipment & Supplies
DCP-135C printing crooked
Hello! I need help!
My Brother printer - DCP-135C
I've changed all inks include the colours.
I able to print the Red, blue and yellow. But I can't print the Black.
I've tried pressed the cleaning option for many times.. Please advise some help.
Rgds, V
Jan 17, 2009 | Brother DCP 130C All-In-One InkJet Printer
DCP-135C
I have ink in my printer. But it doesn't print. always it displays the message INK NEAR EMPTY. how can i rectify that problem?
Jun 15, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-135C Print Quality Settings Not Working Correctly
Have you uninstalled the driver, and reinstalled it?
Are you running Windows Vista? If so, have you downloaded the latest software from Brother's website? www.brother.com
It sounds like the driver is confusing the settings internally, which leads me to think that it is either corrupt or not compatible with your operating system.
Apr 19, 2008 | Brother HL 1440 Laser Printer
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
