Scanner Canoscan 4400F
Will not scan - message 'insufficient space on target disc', but plenty of space.
  • 47 Answers
Posted on Aug 11, 2008
SOURCE:
Canoscan Lide 600F I can't scan bacause I keep getting a message about a target disc????
target disc means hard drive or other disc that the file temporary loads to. its either full or most like write protected. right click on the scanner in control panel or the scanners. select "where" to save to in the popup menus
Oct 09, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
Unable to scan, Make sure there is enough space on the target disk, There is about 200 GB.
check for disk partition permission, be sure you have full permission access.
Apr 07, 2010 | Canon CanoScan 4400F Flatbed Scanner
Using Canoscan Lide 70. When trying to scan receive message "not enough room on target disk" When I reinstall Toolbox it works (for a while, then same repeats).
When you scan a picture, you send it to a "Target" folder which you can set up in your scan options or settings.
At a guess your current destination or target folder is getting to large for the hard drive that its registered on
You've 2 options, clean out the target drive or use the scan options to send your pictures to a new destination with plenty of space.
Mar 05, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Downloaded all the drives and still can use it as the message:"execute appliation" keeps poping up
You need a scanner application such as Adobe Photoshop or other program.
Cannon has one for your scanner at this link.
http://software.canon-europe.com/products/0010399.asp
May 24, 2009 | Canon CanoScan 4400F Flatbed Scanner
CanoScan 4400F cannot scan not enough space in target disk
Easy fix... Happens all the time with all Canon scanners. Open the tool box...click on settings and change the folder where the temporary files are stored to another folder of your choice...or create a new one in your documents. That's it!
Apr 04, 2009 | Canon CanoScan 4400f MultiFunction Color...
Error message: Can not scan. Not enough space on target disk
I have just cured this"not enough space on the target disc" on my set up.I had the problem from day one after buying scanner but learned to get around it.Today I went into Toolbox and opened settings and made a note of the target address. Then checked properties of the target folder and found there was 86mb in a space for 80mb.This was the default setting chosen by the installation programme. I went to my documents and made a new folder and called it Canoscan, clicked ok and it became the new target and the fault is gone. Hope it works for others.
Dec 29, 2008 | Canon CanoScan 4400f MultiFunction Color...
Trying to make a copy- worked last week?
This is most likely only happening when attempting to scan through the CanoScan Toolbox. You can scan directly through ArcSoft PhotoStudio which came with the scanner. However, the error through Toolbox is likely caused by some limitation or restriction in the computer, possibly permissions of some sort. You may try deleting temp files from the Temp folder on the hard drive.
Jul 15, 2008 | Canon CanoScan 4400F Flatbed Scanner
Canon 440f won't scan
I had exactly as described on my new 4400f scanner. Have resolved by uninstalling the toolbox software (it was at 5.0.1.2), downloading toolbox s/w from canon site, file name is S6A04mux.exe - toolbox 5.0.1.1 Installed this and all works from the scanner front panel
Jan 06, 2008 | Canon CanoScan 4400f MultiFunction Color...
Open Questions:
172 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
