Question about Acer Aspire 3000 Notebook
Computer won't start
Ran Window's Washer clean free disk space, it started, then my computer shut off and tried to restart but now it comes up - a disk read error occurred Press Ctrl Alt Del to restart. I did this but it just keeps coming back to the same message. Any suggestions?
My Acer Aspire LapTop will not even power up.
What should we do as this machine has also been charging battery for two days
It has worked before but all of sudden it simply failed to power up.
What's up with this !
Posted on Aug 11, 2008
Why does it take my computer a long time to boot up, loading, and shutting down?
indicates that then hard drive is on the way out
first step is to save everything onto an external hard drive
then take it to a computer repair shop for an inspection
check how much space is on the hard drive because if you have a lot of junk on it , that slows down the start up and shut down p[rocesses
you can go to device manager and do a defrag of the hard drive to free up space
Aug 09, 2017 | Time Computers & Internet
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
My computer is very slow, sometimes freezes or won't load and will not shut down
If your laptop computer won't shut itself down even after you select the "Shut Down" option from your "Start" menu, this means that too many programs are still open on your computer. Before Windows can shut down, it needs to manually close all open software, and having too many programs open can severely delay this process or cause Windows to lock up. Closing these programs will help your machine shut down as normal.
b> Right-click on your task bar. Click "Show Windows Stacked." This will maximize all of the program windows for all open programs on your desktop. The windows will be stacked one on top of the other on-screen. Click the "X" box in the corner of the first window to close that particular program. This will reveal the next program window in the stack. Continue to close these programs until you see your desktop wallpaper again. This, coupled with the fact that your task bar should now be cleared of all program icons, indicates that you have successfully closed all program windows. Your laptop will now shut down normally.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
Feb 01, 2013 | Acer Aspire One PC Notebook
I got a blue screen And the computer shut down. I restarted it and I googled how to get rid of the blue screen and I was told to clean the registry. My antivirus has a registry cleaner so I ran it and it...
start your computer in safe mode ,run auto run manager (download it first from internet ) stop unwanted programs from list , then open task manager , open process list , delete unwanted user process , then open run, type regedit , click export in file option of regit window. Save it on desktop, shut down your computer , run on normally ,click on file that you save on desktop ,click merge to registry. Then it will be fine
Jan 29, 2013 | Computers & Internet
Computer won't come out of sleep
This problem occurs due to various reason: too many software on your startup or your C: drive is full or may be because of virus.
You can do a couple of things:
1. try freeing up your C: drive space, delete unnecessary things and leave at least 15% of space free.
2. Defragment your C: drive, Go to start and write Disk Difragment and press enter. Select C: drive to defragment it (do #1 first)
3. Turn off startup program. Go to start and write 'msconfig', a window will appear, click startup tab where you will find list of software name, untick the software you don't need then apply to restart.( Caution: This step is not recommanded for someone who knows what they are doing).
Jan 25, 2013 | Dell OptiPlex 760 MT Desktop Computer
Deleting updates, freeing space on hard drive
if you are running windows vista, this might help alot, if running xp, it might not, go disk clean up for drive c. to do this, open up my computer, and right click on drive c, and open up properties. click on disk clean up, and a window should show up. if you are running windows vista, its going to ask if from current user, or all users, click all users. after the calculating window, a window that says disk clean up for drive c will show up. click on the tab at the top of that window that says more options, and on the bottom box, which should say system restore and shadow copies, click the clean up button. the longer it takes, the more space its freeing up. Goodluck
Jul 07, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Nothing coming on compter monitor
start the computer in safe mode by pressing the f8.
wait till it completed the loading, log of and restart teh computer and log in as usual.
go to start>>accessories>>system tools.
click on disk cleaner. runit throught the c drive and clean up all of the temp files.
c drive should have 25% free space at all times.
Apr 09, 2009 | Microsoft Windows XP Home Edition
Need to help to clean my recovery H disk is coming almost full.
A hard drive is usually partitoned, one hard drive will show up as two. The recovery drive should not be messed with. Don't add files , nor delete files from that drive.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
Acer Aspire 3000 Notebook Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
