Question about Sony XM-460GTX Car Audio Amplifier
My amp protection light keeps coming on - Sony XM-460GTX Car Audio Amplifier
  • 2 more comments
  • ronaldrb Sep 09, 2008
    can any output transisters work if you want to change them are can u put in an greatter transister work?
    so where can i find the transisters becouse i really like the amp an what will happen if i stronger transisters?
    im not in the US im in the cayman islands
    i dont know which transister i need, where can i get them ?
    when i go there where can i get them?
    thanks its really helping me
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page.
Amp in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Aug 10, 2008
  • 1 more comment
  • Perry Babin Sep 09, 2008
    You need to use the same exact part number as replacements.
    Are you in the US?
    Which transistors do you need?
    If you substitute a different transistor, it could possibly cause more extensive damage to the amplifier.
    First, you need to determine which transistors have failed. The following link will help you determine which are defective.
    Basic Amp Repair
    I can't tell you where to get them. You'll have to find a local source.
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Recvr keeps shutting off and power light keeps flashing. Unhooked the speakers & it still keeps doing it. Tried to go in test mode & still keeps doing it. Please help
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 08, 2011 | Kenwood Audio Players & Recorders
Protect light keeps comin on
MAKE SURE THE GROUND IS GOOD ON BODY OF CAR BOTH UNDER THE HOOD AND WHERE YOUR AMP IS GROUNDED
Apr 18, 2010 | Infinity Reference 1300a Car Audio...
The protection light keeps coming on on my ample audio a 410x amp it was working and now its not whats the problem
Most of the time. If the protection light is on that means your protected. Not that there is something wrong. So if it is working then your fine.
Mar 02, 2010 | Ample Audio A 410X Car Audio Amplifier
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have a 200 watt jensen car amp and the protection light keeps coming on when i turn the gain up.
The amp has no way to cool itself off, so it goes in to protect when it gets hot to keep from breaking stuff and blowing a fuse.
Oct 23, 2009 | Car Audio & Video
Protect light keeps coming on when i give my jensen amp power
Eith some wires touched, you dont have big enough fues or you have somehting hooked up wrong
May 28, 2009 | Jensen LXA300 Car Audio Amplifier
My amp
Check your speakers with an ohm meter. They should have some resistance but not totally shorted. Its prob the amp that got fried. Connect the amp to the battery with no speakers attached to it if the protection light still comes on then the amp is blown.
If the amp is blown you can send it to people on ebay and get it fixed pretty cheap. Good luck!
Aug 18, 2008 | JBL GTO75.4 Car Audio Amplifier
Sony XM-460GTX Car Audio Amplifier Logo
180 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
