Question about RIM BlackBerry 7290
Device error 373 reset
Whenever I switch on my blackberry set I get device error 373
  • 80 Answers
The device is nuked! i have lots laying around with same error and i use them for parts! the device is nuked has hardware errors even if you re install the os it still will error out!
Posted on Feb 27, 2009
Error message - ERROR ENCOUNTERED DURING XML PARSE How to fix?
Hi, you can reset the blackberry with the below instruction..
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Jan 24, 2011 | RIM BlackBerry Bold 9000 Smartphone
Device Error 373 Reset
Hello afterhours!!!
Is seems funny but according to blackberry customers , seems the error is fixed by dropping down the phone on a floor!!!
Not sure about the solution .. But y not give a try on a carpet floor!!
Regards
Smilemaker
Jun 17, 2008 | RIM BlackBerry 7290
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 20, 2009 | RIM BlackBerry 8800
Blackberry 7290 device error:373 reset
Hi Anand
Practically speaking i spent 3 hours looking for your solution but nothing much even the BB intelectuals failed .Try these steps out it may resolve the issue and lets hope for the best .
This error : 373 : Device Error means that the Timers are corroupted
1. Remove the battery for at least 5 minute.
2. Make sure u have working SIM card, other wise remove the old SIM.
3.You should receive an Hour glass spinning. Give a few minutes, after that u will see a 507 message on the bb screen, (which means there is no app loaded on the bb)
4.If this dosent work
Use application loader to wipe handheld clean and reinstall base software but do backup your data
And please let me know .
Apr 04, 2009 | RIM BlackBerry 7290
Blackberry Rim Error: 373.......HELP!!!!
A reset should allow you to turn the device back on.
Hold down ALT+RIGHT SHIFT(CAP)+DELETE simultaneaously for a few seconds.
Aug 04, 2008 | RIM BlackBerry 7290
RIM BlackBerry 7290 Problem:
what button answers the phone
Blackberry 7290
for that problem you should re-install the blackberry system for your pda and it would work! good luck!
May 13, 2008 | RIM BlackBerry 7290
I am getting Device error 373... i coudnt acess my mobile..
is there any solution
Apr 27, 2008 | RIM BlackBerry 7290
Blackberry 7290 reset 373
he device is displaying a message Device Error 373 Reset
How can I resolve this problem blackberry 7290 reset 373 problem
Apr 08, 2008 | RIM BlackBerry 7290
Device error :373 reset
Bang your device hard on the floor a few times and it will come back to life. Seriously!
I REALLY threw it down hard, and then now, after the revolving hourglass for Many many minutes, it's back up and running.
Nov 20, 2007 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
238 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
