Question about Philips Magnavox 27MS343S 27" TV
Demo problem you sent me a question on friday saying we probably accidentally turned on the demo. You asked for my model number and sent it to you. I have yet to get a response. If you need more information please let me know. Bobbie my tv philips just stays on demo
    Genius:
  • 1,074 Answers
Check your remote first it has the demo button just press it and the demo will come off.if it does not come off have a tech change your eeprom and replace it with a new eeprom.good luck.
Posted on Aug 19, 2008
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
I have a panasonic cd stereo system model number sa-ak29 every time that I turn it off 1 second later it come back on.
your system isn't turning back on it is a demo screen. find the button that says something about a demo and press it while the system is off. if that doesnt work press and hold the button while the system is off. if that doesn't work refer to your manual on how to shut off the demo
Jan 05, 2011 | Car Audio & Video
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
Jul 22, 2010 | Toshiba Televison & Video
TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Jul 19, 2010 | Philips Televison & Video
My house lost power earlier today, and now my microwave is not heating the food, and has a lower case "d" in the display after the time. Any suggestions?
It is in the demo mode. To turn off here is what the manual says:
The microwave oven and Timer must be off. Touch and hold Timer Off or the number 3 pad (depending on model) for three to five seconds (depending upon model) until two tones sound and “d” or "Demo" (depending on model) appears on the display. Repeat to turn off and remove “d” or "Demo" icon from the display.
May 10, 2010 | Whirlpool GH7145XF Microwave Oven
Demo mode will not turn off
If the model number you have this listed under is correct, all you have to do to turn the demo mode on/off is the following:
Press FUNCTION, followed by "0" (zero), then press 1 to turn demo ON, or press 2 to turn demo off.
If this is not your model number, please post back with your correct model number, so that I may be able to assist you better.
NOTE: These instructions are listed on pages 10 and 11 of the Owner's Manual.
If you no longer have an owner's manual, you can download one for FREE at managemyhome.com. Just go to the "Manuals" link and type in your model number.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Aug 22, 2009 | Panasonic NN-P794SF Microwave Oven
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Nov 30, 2008 | Philips Televison & Video
Demo problem
to get out of demo mode press ch+ and vol+ on keyboard of set itself and hold for a couple seconds
Jul 28, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
