Question about PfaFF Tiptronic 2040
Machine needle broke, now I can't get it to turn and becomes stuck
Have you checked where the broken part of the needle is? It might be stuck in the race. Take out the bobbin case and remove the sole plate and give it a good clean in the bobbin case and especially around the feed dogs.
Posted on Aug 13, 2008
3 Suggested Answers
SOURCE: machine will not zigzag
Depends on what kind of machine you have. Most of the time incorrect threading is the problem. The needle may be not be tightened in properly, or you may not have selected the correct sequence for zig-zag. Hope this helped a little.
Posted on Jan 09, 2007
Tally Girl
  • 1133 Answers
SOURCE: needle arm stuck
Firstly, do you pull the fabric as it goes through the machine; this is a surefire way to break needles. Tension imbalance shouldn't be breaking a needle; more likely the thread would break if the top tension is too tight. And botton tension shouldn't need adjusting at all.
It may be that your needle is striking the presser foot if you are applying some "pull" to the fabric at the back of the foot.
But sewing very heavy fabrics is a challenge for many domestic machines - upholstery, heavy denim and canvas is tough going for many machines. Some tough mechanical machines will manage it but many won't. You can try using a roller or walking (even feed) foot as this may help with moving the fabric through but often the feed dogs just can't grip and move the heavy fabric enough. If you need to sew heavy fabrics regularly maybe consider finding a 2nd hand industrial straight stitch machine such as the Singer 20U.
In the case of your Bernettte, remove the needle plate (two screws), pressure foot, stub of needle and bobbin and then search the bobbin rotary hook area and see if there is a piece of needle stuck anywhere, you may need to turn the machine upside down and see if it falls out of the race area. I think this machine has a plastic horizontal bobbin case ??? If so, you will probably find that this has dislodged and may have been struck by the needle so remove it and give it a good visual check for damage, if there is a pierce mark, then give this a file down with an emery board to smoooth it. While it is out, see if the flywheel will now rotate the rotary hook fully.
Then reassemble by putting the bobbin case back in lining up the mark on the case with the stopper in the rotary hook, replacing the needle plate, pressure foot and a new needle.
If you can't get it to unlock at all, then it will need to go to a technician for repair.
Posted on Nov 07, 2011
I ran my Juki DDL 8700 without any fabric to test and the threads got sucked in and now the needle is jammed, when I turn the hand wheel it won't move the needle.
Loosen the needle. Once the needle is released, the threads holding it may loosen. Then gently try clipping jammed threads with tiny scissors and patiently try removing cut threads with tweezers..
Dec 21, 2017 | Juki Sewing Machines
Singer 306k Machine was working bery well then needle broke and I cant get the needle to line up with the bobbin case Tried reading manual 100 times Becoming frustrated Pls help
fit the needle correctly as too far up will tilt the needle when you tighten the collar up
there is a stop but it is not very noticeable
turn the machine over by hand (no thread) and see where the needle is hitting the bobbin case. the needle /hook timing may have altered
to check that the eye of the needle should be just below the hook as it reaches the needle
to adjust you will have to take it to a service center.
the needle goes in with the grooved side facing the thread and the cut away bit facing the hook of the bobbin
Sep 13, 2015 | Singer Sewing Machines
Get needle out to change it if it is stuck in the slot because it's broken
Pull needle pie out from below:
Take out bobbin case
Get hold of needle with needle nose pliers
While holding needle, loosen screw up above
Pull needle piece down and out.
Feb 22, 2015 | Singer 3116 Simple
Needle **** screw is jammed
Perhaps your clamp screw is too tight. Remember, "lefty-loosy, righty-tighty". Take your pliers and turn left or take it to a repair-person.
Jul 02, 2012 | Singer Sewing Machines
Brother Innovis 4000 D stopped sewing
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
Jan 29, 2009 | Brother CS-80
Serger Stuck
The first thing a machine needs is oil. Absolutely soak everything that turns. My upholstery machine sits for a while and it gets stuck too. Believe me you don't just turn it. The tolerence is so close its just hard to get broke loose. Use a spray that absorbs rust. then oil good when done
Dec 02, 2008 | Sewing Machines
Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Apr 04, 2008 | Husqvarna Viking 1
Machine is locked up
m8 i havent tryed sewing machines befor but i would take it apart and se wat was casing it to get stuck.also try gettin the skematics for that make and model of sewing machine if nothing else it will atleast give you a better understanding of how the machine works and may help you solve the problem.
Jul 03, 2007 | Necchi 4575 Mechanical Sewing Machine
Sewing Machines Logo
157 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
