Question about Kitchen Ranges
How do i undo the cover of an oven light that has not been changed in 10 years
    President:
  • 1,462 Answers
With difficulty. try a pair of mole grips. you may break the cover if you are too heavy handed
Posted on Aug 10, 2008
How do I replace the bulb for the display panel of a Sharp Microwave oven Model # R-314F ?
Normally switch power off and remove plug from wall socket, undo screws around side and back panel and remove outer cover, then the light socket will be visable so change light bulb and reassemble, CAUTION: high voltage may be present so best left to service person for safety
Jul 23, 2014 | Sharp Microwave Ovens
Oven light burned out and the cover won't come off
i had a look at the model it looks bult in from inside the oven has to have a special tool to undo it he has to take of a few covers also but he should do it cheaper then 99 he is ripping u off call around more people first see what they say
Sep 10, 2008 | Thermador PRG304US Gas Kitchen Range
I need to set the time on my diplomat softline oven
If you operate the grill with door closed, cut-out will come into operation and the grill will not light. pull oven out of the wal,l undo the screws that are in the galvanized cover, lift up the cover and press the red reset button. put it all back together & it should be okay.
Sep 14, 2011 | Ovens
How do i change the light bulb & where can i get the bulb
In most microwaves, the bulb can be accessed by removing the main cover. Unplug the oven, undo the screws that hold the metal cover, and locate the bulb. If the bulb is a standard screw type, it can be found at your local home center. If it is a specialty type, then you can try looking at repairclinc.com
Jun 14, 2010 | Magic Chef MCD1311ST Microwave Oven
How to replace element on my Hotpoint main oven BD31
If it is the main oven element, then undo the screws that secure the cover at the rear of the oven, remove cover, and you will see the round element there.
Undo screw securing element, and pull forward in to oven compartment.
Detach the wires, and fit new element.
Hope this helps you.
Please leave feedback.
Thankyou.
Jan 06, 2010 | Hotpoint Ovens
How do you change the oven light? Cannot undo light cover.
Most oven lights have a wire over the glass globe, pop it sideways & remove the globe.
Nov 30, 2009 | Smeg Ovens
How to change the oven light bulb in a candy f245. Glass cover on inside doesn't seem to undo - moves a bit each way. No apparent access from outside.
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
Jul 15, 2009 | KitchenAid KEHC309 Electric Double Oven
Cant remove glass light cover in oven bosch HBN43M551B
if you remove oven door this will make it easier to undo lens cover
let it warm up then cool down to a point where you can comfortably put your hand in the oven,wear a suitable glove a gardening one is ideal you should be able to remove it once carbon deposits are loosened by heat be sure to turn it correct way when its upside down most of my customers turn it the wrong way tightening it up!
Mar 31, 2009 | Bosch HME9760 Microwave Oven
How do i change the light bulb in my Kenmore Elite Microwave
If it is like a microwave I had, you have to take the whole cover off. Just make sure it is unplugged before undoing the screws.
Dec 21, 2008 | Kenmore 63792 Microwave Oven
Changing oven light bulb
The manual states to turn the cover counter clockwise. I was able to turn it about an inch and then it stopped turning. You really have to apply pressure, but it will turn more. It is similar to a tight light fixture. I was worried about breaking it, but it did finally loosen. I believe the replacement bulb is a 40 watt mini oven bulb also...
Hope this helps!
Mar 30, 2008 | Whirlpool GR460 Electric Kitchen Range
Kitchen Ranges Logo
180 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
