Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
Fridge set up
I bought a fridge and is freezing my food in the fridge.I had it on "3", what is the proper set up dial please?
  • 2,071 Answers
Just try "2" if it frozen your food again and if happen like that,the problem is in defrost heater,check this out..
hope this may help;
DON'T FORGET TO RATE:
Regards,
VOTIT
Posted on Aug 10, 2008
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
I have a FF82 model and it is starting to freeze food. there is some frozen water in the bottom. The temp control dial doesnt move. What shoudl I do to fix this.
Temp dial shouldn't have a setting that would freeze your refrigerator side products anyway. Make sure damper to fridge isn't stuck or frozen which cuts off air from freezer to fridge when temp is achieved. If all working properly for sure. Sounds like bad temp control.
Oct 25, 2016 | Refrigerators
Ho wdo I get my small fridge (Frigidaire model no frc05l5db1) to stop freezing everything.
Sounds like the thermostat is not shutting the unit down and needs to be replaced to restore to proper operation.
Aug 21, 2015 | Refrigerators
My Samsung cooltech freezer and refrigerator keeps freezing all the food in the fridge. It also seems like it is leaking from the freezer into the fridge
turn the temp dial in the fridge down if set on on 5 try 3 and see if that works . there have been some makes that the control has failed and needed replaced .
Mar 02, 2015 | Samsung Refrigerators
My whirlpool fridge is freezing the food in it. What can cause that and how do you fix it?
set at minor temperature,set the thermostat dial at warm temperature.maybe its a little bit empty of food and at full coldest settings
Jul 15, 2014 | Refrigerators
My whirlpool fridge is freezing the food in the fridge. What is causing that?
adjust the temperature settings.change from coldest to colder
Black and decker mini refridge freezes food on lowest setting
The lower the setting the colder the fridge should be, the dial should be turned to the right. A refrigerator should be kept around 35-36 degrees F
Jan 03, 2012 | Food Processors
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
70 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
