Question about Microsoft Xbox 360 Console
Xbox 360 when I hit the start button, I get 3 flashing red lifgts. What can I do?
    Problem Solver:
  • 14 Answers
Call microsoft they may cover it and send you a new system
better known and the ring of death:)
it has to do with the cpu and graphics chip over heating,there was a big recall over most of them and they have been shipping out refurbished units in less than a week after yours is sent in but worst case it never hurts to ask them
anything else i can help you with?
Posted on Aug 10, 2008
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
How do i sync the wirless controller to the xbox
There's a button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around the xbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I've linked a video for both the Xbox 360 and Xbox 360 Slim.
Jun 27, 2011 | Microsoft Xbox 360 Controller
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox has 3 flashing red lights on front. What does this mean
It means your system has the dreaded RROD Or Red Ring Of Death,
If you turn the system on and hold the sync button and then hit the eject button, You can find its code you will have to do it 4 times, 1 light means 1 2 lights means 2 3 Means 3 and 4 lights means 0.
You can usually get a code like 0020 0102 and so on, below is a link that will tell you what each error code means,
also look at the back of your system locate the manufacture date, If it's within 3 years of that date don't open the system call microsoft and have them fix it for free.
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Sep 10, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
What do you do if it is flashing red
If your Xbox 360 power button is flashing red this is because it will be overheating, the most common is 3 red lights, but you may have 1 or 2 as well.
You can fix it using a good Xbox 360 Repair guide or you can send it in.
Dec 25, 2009 | Microsoft Xbox 360 Console
1 red light
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 04, 2009 | Microsoft Xbox 360 Console
Red lights flashing
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
