Question about Kenwood DNX5120 DVD Navigation System GPS Receiver
Losing phone book info
I have the DNX5120 w/ BT-200. I was able to download my phone book, but after killing the engine and then, later on, starting it back up, my phone book info is gone. The only thing that automatically downloads upon connecting is my incoming and outgoing call logs, but the phone book does not. I did see something on line about updating the BT-200, but I'm not sure this would fix the problem. Any thoughts?
  • barnes2000 Aug 27, 2008
    I have been to soundomain and I did do the BT200 update. It's actually working, I just have to go into my bluetooth settings and designate the phone as a special device. After that, the phonebook downloads fine. I just have to do this everytime I start the car.
  • tgavin13 Jan 25, 2009
    Just had the thing installed and got the BT-200 and the HD Turner and my installer said at this point I can only do one or the other so had the HD Tuner put in and every time the system powers down all the resets are lost?
  • 29 Answers
I believe that the 5120 has an EPROM issue and has to be serviced. at least with the HD adapter that's the issue(losing presets).
Posted on Aug 23, 2008
  • Tibor Makai Aug 23, 2008
    check soundomain forum at head unit help section
  • Tibor Makai Aug 27, 2008
    the BT200 update should fix the problem.
Why cant i download books
without knowing what you have , MAKE ,MODEL there is not much help we can look for .
Jan 25, 2016 | Cell Phones
My 2014 Cadillac Escalade loses it Blue Tooth connection with my Kyocera cell phone every time I exit the car or shut the engine off. HELP!
its a power problem take the feed for BT direct from battery, so when other power is drawn it dont reset the BT?
Aug 21, 2015 | Kyocera Cell Phones
Why won't my Husqvarna 150 BT blower shut off? It starts and runs great, but won't kill with the switch.
Kill switch most likely has broken wire between switch and engine. When in "kill" position, it should connect the top of the sparkplug to the rest of the engine. If it doesn't, either the switch is bad or the wire is.
Jun 15, 2015 | Husqvarna 150BT 50CC Gas Leaf Backpack...
I just change the phone on my cannon mx310 but cannot get a dialing tone on phone
I would check with your phone service provider to check for any fault on the line . I had the same problem with my phone and it was a fault with line . It was alright a couple of days later . The bt engineering team discovered it was a fault underground
Nov 10, 2014 | Canon PIXMA MX310 All-In-One Printer
How to break the security code in a cell,not to unlock, just to get in like to make a call or see the phone book,etc
There is a java program that you can download called "bt info" that lets you get into peoples mobile phones via bluetooth.
To my knowledge, this program is only available via torrent sites but a friend of mine says that you can download it from a few websites.
I have this on my phone and let me tell you, IT WORKS!!
You can make calls,read txts,set there alarm off and many other things
Hope this Helped!
Oct 19, 2009 | Cell Phones
Have bought BT Verve 450. Am looking for the MUTE
Hi, If you press the button phone book button - Looks like a book symbol.
Whilst in a call the handset will show "Mute On" press the button again to unmute.
Hope that helps.
For the BT Verve 450
Ryan - Worldhosted
Sep 15, 2009 | Uniden Cordless Phone
Trans slip when pulling toy hauler
Heat is killing your transmission. Change the transmission oil and filter and slow down. Pulling something that heavy is best with a manual transmission.
Jun 15, 2009 | RTO Automatic Transmission And Engine Oil...
Engine timing for a 1998 subaru forester with a 2.5
Since ignition timing is taken care of by the ECU, I guess you are asking about cam timing.
There are several marks to be aligned and if you get them wrong, you may trash your engine so I am only going to suggest you buy a Haynes service manual that has numerous good pix that show you exactly how to avoid killing your engine. And, unless you have a good-size vice well-mounted, compressing the belt tensioner again is going to give you fits.
The Haynes number you need is 89100 but it is listed only as a manual for the Legacy which uses the same engine but there may be less info that is usable on your '98 forester for which Haynes does not make a specific manual.
The later book that I have, 89101, covers all models from 2000 to 2006.
Aug 11, 2008 | 2006 Subaru Forester
Address Book Dissappears
You need to flash the phone with upgrade firmware.
May 18, 2008 | Motorola Mobility V190 Cellular Phone
Kenwood DNX5120 DVD Navigation System GPS Receiver Logo
160 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
