Question about Janome 1600P-DB Mechanical Sewing Machine
The thread keeps getting caught in the bobbin area.
Turn the bobbin around in the case so that the bobbin turns in the same direction as the thread is flowing. If you pull the thread in the case and the bobbin turns opposite the flow of the thread then you might have a problem.
Make sure the shuttle is in place, you will have to look at the manual for this. Replace the case and bobbin. Make sure you have a good needle in place.
Posted on Dec 12, 2008
SOURCE:
Why is my thread getting caught under needle plate?
try changing the needle
make sure the thread has not come off the thread take up lever
try turning the bobbin the opposite way
Jan 09, 2013 | Janome Sewist 625e
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
I just got a new Singer Simple. I had a problem with the needle thread getting caught in the bobbin shuttle. I disassembled this area, found a random thread, and cleaned it out. I put it all back together...
Do you have the bobbin thread going the right way, according to owners manual some go clock wise some go counter clock wise when you pull the thread after bobbin inserted in bobbin case
Dec 27, 2010 | Singer 3116 Simple
The top thread keeps getting caught in the bobbin case on my machine.
Most likely causes:
  1. You haven't removed pieces of thread in the area around the bobbin case.
  2. The top thread is not properly installed. (Quick check - The thread is under tension when the needle is at the bottom of it's travel.)
Dec 18, 2010 | Singer 2662
Brand New 2263SImple. Thread keeps getting caught up in the hook in the bobbin area. Went by manual, still does it.
check your needle to see if it's damaged
some sewing machines do this when the upper thread comes off the thread take up lever
make sure thread is thread thru all the thread guides
check bobbin area for lint & loose threads
Sep 25, 2010 | Singer Sewing Machines
Why does my thread keep breaking and why wont the sewing machine stich?
sometimes the thread can get caught on the spool pin
or on the notch on the thread spool itself
on some machines the thread can come off the thread take up lever
it can also get caught in the top tension area
also check your needle to see if it's bent--roll on flat surface to see if it rolls correctly
there are 3 types of bad needles-bent
blunt--makes a popping sound when going thru fabric
damaged--broke tip
also check your bobbin area for lint or loose threads
check your bobbin to see if it's warped--I've come across some that were warped
check your top thread tension
Sep 24, 2010 | White Sewing 2200 Multi-Tasker
The thread gets caught in the bobbin case area and does not for a stitch and becomes entanged.
some sewing machines jam in the bobbin area when the thread comes off the thread take up lever
check the bobbin & bobbin case for burrs
Sep 23, 2010 | Janome Sewing Machines
I keep having the same problem. I have the 7133 sewing machine and the top thread keeps getting stuck on the bottom. It's not the bobbin thread that does it but the top thread which gets caught on the hook...
Sounds like insufficient tension on the top thread. THIS may be due to variation in the thread itself or incorrect adjustment.
ALSO I recently found out that some bobbins have a metal core that can catch the thread as it goes over. The person recommended using the plastic bobbins that have smooth angled sides.
Nov 20, 2009 | Euro-Pro Shark 80 - 7133
Bobbin thread pulls and breaks
Has this problem only just started?
Sometime when this happens to me it is because the upper thread has somehow become threaded incorrectly. I take it all out and rethread - then all is ok.
Tension in the bobbin may also me an issue
Stephanie
Jun 23, 2008 | Husqvarna Rose
Janome 1600P-DB Mechanical Sewing Machine Logo
128 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
