Washing machine -Springy/popping noise on wash cycle
My washing machine makes a springy-popping noise when it starts rotating on the wash cycle. It's often a few noises all in a row just as it starts rotating in a direction (rotates in both directions). When on spin cycle there is no noise.
At first I thought it was being overloaded but it seems to make the noise all the time now.
2 Suggested Answers
SOURCE:
  • 641 Answers
SOURCE: my washing machine
Open washer's rear panel and look for a released or a malfunction shock absorber Good luck!
Posted on Aug 27, 2007
The conditioner is not being pumped through as normal on wash cycle? Is this a blockage that can be fixed easily? Cheers Steve.
Do the cheap things first. Remove the top and check the supply hoses for blockages or kinks. Get a length of springy plastic to thread down the hose to see if there is dried residue. When the top is off try a cycle that uses conditioner and see if it tries to empty the tray.
Dec 29, 2014 | Hotpoint Washing Machines
The start/pause button has been pushed in too far and I would like to know can I fix this???
that happened to my machine once, I gently wiggled it whilst very quickly giving it a springy type push and it popped out again. if that doesn't work, Make sure your hands are DRY and UNPLUG the machine from elec remove lid and reach inside and release the spring.
Jan 03, 2013 | Washing Machines
We have a Bosch Washing Machine nexxt 100 series wfmc1001uc, the water lines froze without us realizing, we started to washer while lines were frozen... in the end, we had to replace the hot water inlet as...
Bosch Washing Machine nexxt 100 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 05, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Spin cycle doesn't spin. During wash and rinse cycle the agitator does rotate back and forth.
You may have a broken interlock switch underneath the lid. Lift lid and somewhere on the right side is a hole. Under it there is a plastic arm, such that the machine won't spin if the lid is open. There should be a plastic 'finger' on the lid. check that out, Gently pushing a popsicle stick down the hole. Thwere should be springy resistance, or look down the hole with a flashlight and see if a plastic finger is across about the middleof the hole.
I hope this isn't too much info for you. Let me know.
Jan 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Wash machine model mav 7600, started making tremendous noise, first in spin cycle only and then in wash cycle also. After running a few loads with the noise the machine just stoped running....
This sounds like collapsed/broken drum bearings. Check for movement between inner and outer drum. Also rotating the drum by hand will be hard (or immpossible), and noisy. It could be the motor and belt, but most times it is bearings.
Aug 11, 2010 | Maytag Washing Machines
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Drum on LG front load washer does not turn.
something is caught in between the two tubs.and that is no fun! call the tech.ps there is no belt on most lgs.
Aug 07, 2009 | LG Washing Machines
The door to my lg washer won't open - can you help
slide a flat tool (paint scraper,screwdriver )between the door and machine body where the door latch is.you should be able to push the latch open. worked for me.
Jul 12, 2009 | LG WD-16115FD Front Load Washer
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
My washing machine
Aug 27, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
