Question about Samsung DVD-909 DVD Player
Samsung DVD-V6700 Hi I am having trouble playing copied disks -R in the DVD player I insert ,,there is no message on screen except OPEN and the machine just opens the player and ejects the disk with no message at all It appears it only rejects movies copied in approx 2007/2008 Is there some new iencryption we dont know about The set is SAMSUNG DVD-V6700 The disks will play in a SONY and an LG player that I own... Regards Mike Cooper
SOURCE: Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
  • 6 Answers
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
Obertelli
  • 3006 Answers
SOURCE: I have a region 2 samsung dvd player. All of a
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Posted on Jul 03, 2009
chipsandnuts
  • 70 Answers
SOURCE: Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
Posted on Jul 04, 2009
I have lost my Samsung V6700 manual. How can I get a copy.
Hi!
you can download it from here for free...
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 07, 2011 | Samsung DVD-V6700 DVD Player/VCR
Tip
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
on Aug 02, 2010 | Samsung DVD-P241 DVD Player
My dvd player wont play a disk
Try cleaning the lens with a CD/DVD cleaning kit that you can buy at a local electronics store. If you have tech skills, open the player up and clean the glass eye reader lens with some rubbing alcohol using a Q-tip. Make sure the DVD you are using is not too scratched up. If it still don't play after you have cleaned it and tried a different DVD disc then replace the optical reader drive if it is still under warranty
Nov 04, 2009 | Samsung DVD-V6700 DVD Player/VCR
DVD door will not open and dvd not play. Just less than 12 monthes old. Brought in NZ.
Hi there ,
If there is a disk stuck inside, then try the following:
Unplug power cord.
Plug back, and then press repeatedly the eject button while the unit is starting up.
Do this a couple of times.
If the above did not work, or there is no disk stuck inside, then wiring to unit motor, or mechanics may be broken.
In that case the unit must be taken apart, removing screws at the back and sometimes at the bottom to take out the upper cover.
Aug 04, 2009 | Samsung DVD-V6700 DVD Player/VCR
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
Unlocking code for Samsung V6700 DVD/Video combi for region 1
I need to unlock (play any region) GPX D1816 DVD
Any help appriciated
Thanks
Jan 20, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Region code for Samsung DVD-V6700
1. Make sure there is no DVD in the drive. The player must be empty. Turn on the player, (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the USA ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 29334
Nov 15, 2007 | Samsung DVD-909 DVD Player
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Open Questions:
Samsung DVD-909 DVD Player Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
