Question about ASUS P4VP-MX Motherboard
Display problem no display and very hit the board power section component
  • 1 more comment
  • omlekzkie Aug 22, 2008
    If switched on, it dosn't boot up, no beeping sound with or without memory module or video card but the green led light and the cpu fan turns on
  • Anonymous Mar 13, 2009
    no post
  • Anonymous Mar 21, 2009
    me too v.v
Try It To Restart The Jumper of Motherboard..if The Display is not working again..try it remove the processor then after 3 or more minutes back again then try it restart the jumper..
Posted on Apr 26, 2009
  • 3 Answers
Culo
Posted on Nov 24, 2008
My tv wont stay on when i hit the power button
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 02, 2017 | Televison & Video
Samsung plasma TV model #pn42b400p3dxza problem with no image. The TV has sound but no image. I've tried using other components on the TV like RCA jacks with a separate TV digital tuner. Thank you
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Check whether Va & Vs voltage come to the display panel, from the main power supply regulator board. If not, the SMPS board [power supply regulator board] is faulty.
Jan 08, 2017 | Samsung Televison & Video
Rca led50b45rq will not power up or come on
Nov 21, 2016 | RCA Televison & Video
My telefunken lcd model tlcd 40fhdb does not display but sound is there. how can i solve without a remote. if i switch on it displays for 2 seconds then display goes off
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 18, 2016 | Televison & Video
Have a LG Led Tv with audio but no display
Sep 26, 2016 | LG Televison & Video
My Hisense 50 inch smart tv will not turn on. Power light shuts off when I hit the power button but my screen is black.
Sep 18, 2016 | Hisense Televison & Video
TV QUIT WORKING
Aug 21, 2016 | LG Electronics 47LB5900 47-Inch 1080p...
My sharp cd-s360 mini component system the display will not light up ?
The main power supply regulator section fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 29, 2016 | Sharp Audio Players & Recorders
Have a flat screen that come on an then go off
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 09, 2015 | Televison & Video
TV hit by lightning strike. Replaced blown fuse, still won't turn on.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 05, 2014 | Televison & Video
ASUS P4VP-MX Motherboard Logo
99 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
