Question about Fisher and Paykel GWL11 Top Load Washer
Cold Water fills VERY VERY slowly (i.e 2 hrs to do a load)
I have a problem with the cold water not coming in as fast as it used to.  A post said it was an easy job to replace the part.  If this is true I would love to fix it - but I don't know what part to order, and how to order it.  I'd also like to know if this is truly an easy job, and it this problem not an unusual one, so this solution is probably the correct fix for the problem?
Thanks in advance for any help you are able to provide.
  • mfarkas Aug 20, 2008
    Is there a place where we can see how to replace the cold water valve? And do you know where we can buy the part?
    Thanks
  • 6,487 Answers
Try checking this link this may help you for this concern http://fixitnow.com/2004/10/appliance-repair-revelation-fisher_30.htm
Hope that helps.......
Posted on Aug 20, 2008
    Scholar:
  • 191 Answers
All you need to check the inlet, normally there is a filter attatched with the inlet line which prevents dirt to enter the machine so that must be blocking the path for the water to enter all you need to do is unscrew the inlet and check for the clogged filter located in the hose pipe attachment.
Posted on Aug 19, 2008
  • Moses Clive
    Moses Clive Aug 19, 2008
    The hosefilter looks like this please clean it to get the water supply faster.
  • 1,512 Answers
Hi
First thing to check is that someone has not turned off the water tap to the machine. If you have the double tap arrangement over a sink, a common problem is people turning the wrong tap off. Check and see :)
regards
robotek
  • 4 more comments
  • Graeme Ross
    Graeme Ross Aug 19, 2008
    If the taps and filters are letting the machine get water, here is a decent guide on your machines internals.
  • Graeme Ross
    the part you need if a valve is required is Part
    420147
  • Graeme Ross
    you can get the parts listings for your machine here
  • Graeme Ross
    and source the part from here if you live in Aussie
  • Graeme Ross
    oh and the parts listing has exploded views on how the machine goes together. Everything you need. If you don't live down under... let me know and I can find a supplier where you are. Feel free to ask any questions you may have:) Good Luck
    regards
    robotek
  • Graeme Ross
    Graeme Ross Aug 22, 2008
    Hi,just a follow-up to see how you got on with sorting out the washer. Did you get the the link and manual for the machine I have posted for you?
    regards
    robotek
    Genius:
  • 2,035 Answers
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Posted on Aug 10, 2008
    President:
  • 778 Answers
It is an easy job, as the valve and solenoid mechanism are what the cold and hot water hoses connect to (at the back of the machine) and tilting the machine forward, and maybe removing a cover you'll have easy access to the switching valve (at least on most of the washers I've worked on the valves where easily accessible),
You can tilt the washer forward and take a look for yourself before you decide to proceed.
Good luck and happy DIY.
Cold water fills very slowly
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Jan 02, 2013 | Roper RAS8445KQ Top Load Washer
Not getting enough water
Hi just read your posting.Now what water temp are you using for you wash cycle?Is it cold , warm or hot?Problem could be your cold water valve not opening enough or your motor controller.If you selected a COLD wash how fast does your cold water come in to the machine?Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Tub filling with water after cycle is finshed
If your washer fills with water, usually slowly, after the cycle is over you have a inlet water valve which is not shutting off completely. LG usually uses a separate valve for the hot and cold. If you turn off the valve where the hose comes from the house and observe for continued water fill, first one, the reopen it, then shut off the other you should be able to see which (hot or cold) is the culprit. If you post your exact model number I should be able to list the part numbers for you. The inlet valves I am speaking of are the part where the hoses connect onto your machine.
Nov 07, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Just want to know how to get the fasted wash as it seems to take about 1.5 hrs to do a load. zanussi xc6 1400
Check your screens on the fill valves. This is a good time to replace the fill hoses, the last thing you need is an old one to blow. Wash warm, rinse warm, both fill valves will be open. If you only use cold water, hook both fill valves to cold water, cold water will go thru the hot fill valve for a faster fill.
Aug 18, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
89 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
