Execuflite hi proton77, this printer hasnt been used for some time ( at least 6 mths) Its not my primary. It goes with a computer that stays in our airplane. I just pulled it out yesterday to do a print job and found this problem. This particular computer did go to the repair shop about 3 months ago but as ive stated I havent used the printer in some time.
  • 1,183 Answers
The printer has mechanical problem , would need to be sent in for repairs again. The Solenoid laser is the cause of this problem ,it would either required service or replacement.
Thanks
Proton
Posted on Aug 10, 2008
I for got the passcode for my ipod toch and it finally told me to plug it in and hasnt worked since . told me it is disabled
Hi ericamaebell...
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please take time to rate me
Jul 18, 2011 | Apple iPod touch
My cannon Pixma ip90v is showing error 6800. Is there a simple fix that I can do without bringing it in for repair?
hi,
when did the problem start and was there any windows update , after which the problem started ?
Thanks
Proton
Aug 10, 2008 | Canon Office Equipment & Supplies
Sony rear projection standby light stays on color red, has no pic or sound ? help please.
Hi,it sounds like its time to replace the lamp,especially if tv is between 2-3 yrs .Any clicking noises? if you do it could be an issue with the board that powers the lamp it's called the ballast.Your lamp is made by Philips and it last 6000-8000 hrs ,make sure you get the original, generics dont provide same quality and life time is way shorter 4000 hrs 6 mths - 1 yr.Have a blessed life!
Nov 17, 2009 | Televison & Video
A215 speakers fuzzy noise
Have you got a power supply unit near the speakers (move any power source away from a speaker). Other than that then one of your cables has a short in it.
May 17, 2009 | Dell A215 Computer Speakers
We have high speed internet now. Before we had dail-up. I can not syc my pda with my computer. What do I do not?
As , there was no response , for a long time on the chat , i had to end the session.
proton77 says:
Alternative support option is available at
proton77 says:
chatsupport.palm.com
proton77 says:
click on the option > continue without download
proton77 says:
thanks
Nov 01, 2008 | Computers & Internet
Problem
Hi Juliet_34tx,
1) right click on "My Computer"
2) click on "Advance" tab
3) click on Performance settings
4) click on "Advance" tab
5) in the bottom (Virtual memory) box click on "Change" button.
6) click on the radio button for "Custom size" and make the adjustment.
Note: A good rule of thumb ;
Initial size = 1.5 times your primary memory.
Maximum size = about 3 times your primary memory.
or you can use what your system recommends.
Good luck
Aug 26, 2008 | Computers & Internet
Service engine soon & brake light stays on
the service engine light is prob due to the oxygen sensor being damaged, not replace or you having the catalytic converter taken off---just messing with you. start at auto zone and have then do a free code read then go from there. you should troubleshoot the low fluid level switch for your brake fluid. unplug it and see if the light goes off and if it doesn't jump the two terminals on the harness. oh the car will have to be running. Let me know MrRodneyLong@gmail.com
Jul 04, 2008 | 2000 Ford Mustang
Cant install.
Your best bet is to go to the HP website and perform a search for Win 98 Drivers to download for your printer, if you don't have any luck there, try searching for the drivers through an internet search engine. eg Google.
Matt Coyote.
Feb 20, 2008 | HP DeskJet 710c InkJet Printer
jasbo
jasbo
