Question about Maytag MSD2656G Side by Side Refrigerator
Maytag side by side slowly getting warmer
My Maytag mod. MSD2656dew has stopped cooling everywhere but started with the refrigerator side,then the upper freezer. Now the lower freezer is at 35degs. The fan inside sounds like it's working but I don't feel much air flow. The fan by the compressor is running, but the compressor only runs for 5 or ten sec. at the most,then clicks off. It does this several times every couple of minutes after it's first turned on, then stops.The compressor is warm, but not hot.I dont see any ice in the vents either, but have not removed any internal covers. It does seem to be making ice, but very slowly. This problem started after the refrig. door was left partially open several times due to a shelf in the door hanging up. EXACTLY THE SAME PROBLEM, FRIDEGE STARTED COOLING OFF TWO DAYS AGO, THEN THE FREEZER EARLY YESTERDAY, AND TODAY, THE FREEZER IS DRIPPING. I JUST BOUGHT IT USED AND TURNED IT ON LAST FRIDAY (ONE WEEK AGO), AFTER LETTING IT SIT FOR 10 HOURS. I DON'T HAVE A MANUAL, BUT THE MODEL IS A MSD 2656DEW - "MAYTAGE PLUS"... THE SERIAL NUMBER IS 12584578YK. I WAS TOLD THE FRIDGE WAS 1.5 YEARS OLD. THE FRIDGE WAS WORKING FOR THREE DAYS, THEN BEGAN GETTING WARMER... NOTE!!!! I DO NOT HAVE WATER GOING IN TO THE FRIDGE. I CAN SEE THAT THE HOSES (THINK CLEAR PLASTIC) ARE GOING BACK UNDER THE FRIDGE. I DON'T HAVE A MANUAL TO LOOK AT EITHER. ANY HELP IS MUCH APPRECIATED. THANKS!
    Genius:
  • 1,847 Answers
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Posted on Aug 10, 2008
  • Legin Varghese
    Legin Varghese Aug 10, 2008
    The fan in this refrigerator should always run when the compressor is
    running. The fan in the freezer section is called the evaporator fan
    motor.if the evap fan motor doesn't run, The upper sections of the
    freezer will also be warmer than the lower sections. Depending on the
    age of the unit, it's probably a small, white body Panasonic fan motor.
    This fan motor has not proven itself to be worth the plastic it's made
    of. It is probably not a connection problem, rather a bad fan motor. At
    this point, you have one of two options: 1) go to a local appliance
    service depot and ask for Maytag Genuine Parts part number 61005339; I
    charge $90.00 for this motor, so you should expect about that much. 2)
    go to an appliance repair depot that has a local Johnstone supply
    account and ask for part number S58-099: I charge 36.00 for this motor.
    This is the motor I use regularly. If you use the Johnstone motor, you
    have to reverse the rotor so the shaft rotates the same way as the
    original, which is a very simple operation. The Johnstone motor won't
    have the exact connections as the original, but I always try to connect
    the new motor leads in such a way as to not cut off any factory harness
    connectors, whenever possible. If you use wire nuts or bell terminals,
    it is best to fill the connector with silicone after you crimp it to
    keep moisture out of your connection.
    If this information was helpful in anyway
    Kindly Rate Fixyaa..
    Thanks
Hello I have 2005 maytag fridge. The freezer went out yesterday and now the fridge side is slowly getting warmer. It makes a buzzing noise every few minutes but all lights still work on both sides.
That is most likely a bad starting capacitor for your compressor. Have a serviceman take a look at - should be a couple hundred dollars providing nothing else is wrong.
May 02, 2017 | Maytag Refrigerators
Hello, I have a Maytag side by side fridge that is 26 cu. ft. The freezer has stopped working and the fridge is slowly getting warmer. I have tried unplugging it and plugging it back in. This has not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag Freezers
My refrigerator simply stopped cooling all of a sudden. It has been slowly getting warmer over the course of... 2-3 days, and this morning it stopped cooling all together. The power is on, the temperature...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 25, 2010 | Maytag PTB1953G Top Freezer Refrigerator
Refrigerator not cooling: Maytag Plus: Model MSD2756GEQ
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
Aug 15, 2009 | Maytag MSD2758G Side by Side Refrigerator
Freezer suddenly defrosted!
sounds like you may have one that's in the recall..search maytag recall refrigerator and see if yours is one of them.free repair.
Jun 12, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Model MSD2732GR side by side refrigerator has intermittently stopped cooling for quite some time now. Unfortunately, it is now more frequent- the freezer defrosts and gets warmer spoiling all the food as...
Click on the link and you will see where your defrost timer and themostat is. without being there to hear the noises start there. See if the fan in the freezer and the fan behind at the bottom of the refrigerator in the back are working and you get good air flow. You are in luck because you have a mechanical defrost timer vs. a computer one but start there. to turn the compressor on and off there will be an access hole to the timer that you can use a screw driver on to slowly turn it to tun on the compressor...you will hear it come on. Leave it there once it comes on and if it cools properly for 6 to 8 hours and then stops cooling again your timer my be sticking in defrost. replace it. sometimes fans run intmittantly so dont forget to check them out...let me know here is the link...good luck....copy and past from http to the end.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MSD2732GRQ&productCategoryId=0165000&brandId=3048&modelName=MAYTAG-REFRIGERATION&diagramPageId=00002&componentDescription=CONTROLS (MSD2732GRQ/W)&documentId=M0310671&backToLink=Return to Sub Components list
May 13, 2009 | Maytag MSD2732GR Side by Side Refrigerator
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Coils freezing up on my maytag msd2656dew refrigerator
Replace the thermostat...I had the same problem...I checked the fan, defrost heater and Adaptive Frost control and could not find anything wrong. Replaced the thermostat and the problem went away.
Nov 06, 2007 | Maytag MSD2656G Side by Side Refrigerator
I have a Maytag msd2422gr side-by-side that has gradually stopped cooling 2 or 3 times.  The solution is cheap and easy: Your unit isn't cooling because the space in which the fan is housed is so full of ice you are getting no cold air circulation. The compressor and everything else is functioning, but the cold that is being produced is blocked by ice. All you need to do is to unplug the unit and entirely unload the freezer. Locate a panel with vent slots on the back wall of the freezer compartment that covers the fan. It is held on by about 4 screws. Lift out the panel and behold the glacier of ice covering the coils. You might want to use a hair dryer or space heater to hasten the melting, but I would warn against trying to chip or break it out because you will probably ruin or puncture an important part. Once all the ice is gone, reassemble and plug it back in. As I recall, it takes a few minutes for the compressor to get going again, but be patient because, if there was ice, that was your problem and if it is now gone, that is your solution. It can't help but work. And from now on, you know to be careful not over-load and block those vent slots in the back of your freezer.  If all else fails go here and get great, free help and every part you could possibly need:  http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Mar 27, 2007 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
563 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
