Have a britony combi se boiler .heating does not stay on.incorrect function light is on code 60. describes as ionation printed circuit board faulty
  • Anonymous Nov 15, 2008
    i hae the same issue..
    the book states that it is bellow
    Ionisation printed circuit board faulty.
SOURCE:
  • 334 Answers
SOURCE: have a combi boiler and
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Posted on Dec 06, 2008
  • 30 Answers
SOURCE: re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Posted on Mar 30, 2009
  • 13 Answers
SOURCE: I have a britony combi se 80. It keeps cutting out, error 60.
hi mate if you are happy to open the appliance and not disturb any gas connections clean the rectification probe, cause if its a intermittent fault it could be carbon deposits on the probe also make shaw the lead from probe to pcb is connected and not damaged if all ok its the pcb, let me know
Posted on Sep 12, 2009
  • 308 Answers
SOURCE: Britony Combi se 80 boiler
Steel wool is the way to clean. Hope this helps
Posted on Nov 12, 2009
  • 383 Answers
SOURCE: Britony 80 combi boiler G31
You gave a good description of the boiler--
now we need to hear the clues you have observed, as it fires (or fails to fire-- or what?)
Or as the water flow-- or doesn't flow?
As the cold water enters-- what does the flame do?
And does the flow rate reduce as the flow gets to the divert er valve?
How old is the boiler?-- and have we been using HARD water?
(Any water softener in the circuit to remove calcium and magnesium, etc.?)
Do you suspect a scaling problem in the interior parts?
If so-- can you circuit an acid thru the innards, to clean up the scale?
Please comment on what happens when water and gas flow-- so we can help you get to the next step.
Mack B
Posted on Jan 17, 2011
Chaffoteaux britony combi 80 I've just replace both pcbs and still have a pulsing flame after ignition. It burns for a few seconds then cuts out. Ideas?
this sounds like a central heating boiler rather than a computer. can you please post in the correct section where you'll get a meaningful response.
Mar 14, 2014 | Computers & Internet
Britony 80 combi boiler G31 propane, gas flow rate =0.124877 cubic meters per hour, inlet pressure 37mbar, room sealed flu Manufactures recommended Co2 & NFGT unknown, cold water from hot tap when...
Mack B
Jan 17, 2011 | Heating & Cooling
Britony boiler problem
check diaphrapm chageover valve
Oct 30, 2009 | Water Heaters
Oct 18, 2009 | Water Heaters
Sep 09, 2009 | Combi Centre DX - Mango
Re: combi boiler.
Mar 23, 2009 | Water Heaters
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Gushing Water
sounds like youve topped the pressure up too much, the boiler needs to be on 1 bar pressure from a cold state, thats the max really you want to increase it too, in operation the boiler pressure increases due to heat expansion but sounds like you may have more of a problem, if your renting the property then its the landlords duty to ensure your boiler works and its safe- consult the landlord asap and they sohould help you out
Apr 21, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
