Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Air flow blockage
I have a mitsubishi WD-52631and an error comes up that says that there is an air flow blockage and powers down. i cant find any blockage what do i do???
    Problem Solver:
  • 5 Answers
Take care of it NOW. We ignored the error (knowing we're under a service plan so we'd get to it eventually). Then last week the TV just cut out and we got no picture and the red lamp light came on. Service guy came out today and replaced the lamp and it didn't work and then called Mitsubishi. They said it is probably a very common capacitor problem on the power supply board. If you open the back and take a look you are likely to see bulging caps. Parts C9A37 and C9A38. The caps are cheap if you can find them, but the parts are really hard to find right now so Best Buy is actually replacing these for people under service plans rather than fixing them. The message you are getting is a sign that the caps are getting too hot and need to shut down to cool off... It will eventually ruin your lamp if you let it go on.
Good luck! BTW, our guy said the repair will run you about $200 if you can't do it yourself, but someone else on this board with guru status recommends a kit that comes with a CD and a manual that will help you fix this. They even give a web address to order it. If we weren't under a service plan I would be going this route...
Posted on Aug 13, 2008
Air flow problem
Pull Lamp Out and see if when you try to turn it on if the Ballast Board has a spark/arking noise coming from it? If So Replace the Lamp.
Jan 14, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Air flow blocked come on screen and then shutts down
Call Mitsubishi they will tell you an authorized service center in your area to come out and change the thermal sensor in this set free of charge.
Oct 17, 2009 | Mitsubishi WD-57732 Projection Television
Error / problem message
these are on mitsubishi's recall list you need to get in touch with mitsubishi and have them find a authorized servicer in your area to come put a thermal sensor in your set.
Aug 12, 2009 | Mitsubishi WD-57732 Projection Television
Error Message
If the set is only 3 1/2 months old, you should still have warranty coverage. Opening up the unit will void the warranty, so don't open up the set. Call for warranty service. In all probability, the air flow sensor is defective. The message you are seeing is a result of the air flow not being detected or not sufficient. In any case, this is a covered problem and should cost you nothing to fix.
Dan
Mar 20, 2009 | Mitsubishi WD-Y65 65" HDTV
Airflow blocked tv will shut down after a few seconds
Good Day;
If you have a WD-52525 Model TV and the the screen displays "air flow problem" change the sensor. There's not a positive way to check device, just replace it, trust me. IF your TV is a different Model MIT'S has a recall on those certain Models. REPLACE.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Auto power down
have you tried cleaning the air filter?
Mar 26, 2008 | Mitsubishi WD-65731 65" HDTV
Air flow
Hi.
Have you checked vents for blockages & ensure fan can rotate freely.
Oct 09, 2007 | Televison & Video
Air flow error
There is a Mitsubishi service bulletin for this problem.The source of the problem is the connector to the thermal fuse by the lamp. The fix is to cut the connectors off and hard wire the fuse (you will have to splice in a 3"inch wire extension to make it reach once the 2-wire connector is cut off)
Aug 30, 2007 | Mitsubishi WD-57731 57" Projection HDTV
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
