Question about Mitsubishi VS-50603 50" Rear Projection Television
Will on ocassion power on and get sound and image
I just learned about this site from a friend after he gave me a nice and clean looking vs50603 Tv it worked for a few weeks no prob then i tried to turn it on a few days ago and i got sound and power and then image for all of 5 sec out of first instinct i unplugged for around 12 hours turned on for a couple of minutes
and all of a sudden no image no sound all went black
im a newb but im a fast learner any ideas on what might be wrong?
if nothing else point me in the right direction and ill be happy
or is there a link where i can view the manual online
  • Mitsubishi Master
  • 8,617 Answers
Press the menu and input/device buttons both in together on the front panel and hold in for 5 seconds to see if the Led will blink a two digit blink code. Then let me know what the code is., and I will help you with the problem.
Posted on Aug 10, 2008
I have a Emerson 42 inch LCD TV.. power comes on,and the screen lights up. But does not display any images. Not even when you push the menu or the input menu button
first of all make sure you are on the correct video stream.. (HDMI 1, HDMI2, etc) of Aux , Com.. or just plain ole Channel 3 or 4,, if all that fails it sounds like it might be your T-Con card. I had the same problem with TV I fixed for a friend and that was an easy fix. in fact he just gave me the TV after I fixed it. and it is still working.. I usually check with Shopjimmy.com for parts. if they don't have them in stock then I check with eBay,Amazon. or just Google the part number and find one there..
Sep 22, 2014 | Televison & Video
I have a philips magnavox 64" rptv, "99", model 9p644c. The picture is real dim. a friend gave it to me, but don't want to spend a ton of $ if I can buy one cheaper. Doe's it just need a bu
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 21, 2013 | Philips 9P6444C 64" Rear Projection...
Panasonic plasma tv 50 inch 720p TH-M50HD18 red light blinks 10 times
In an earlier review I gave this product 1 star. Not because of its performance, but because I couldn't understand how to use it. The web site looked nice but was hard to follow. I really wanted it to work for me, but finally gave up. I really wanted this device to work for me, and now it does fitness tracker reviews
Jul 07, 2012 | Panasonic Televison & Video
Power light stays red
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 30, 2012 | RCA L26HD35D TV
Mitsubishi 50" Projection TV (Model VS-50603) Has sound but no picture
MJBNATL:
I reluctantly scheduled a technician to come out next week and take a look at my set. I was going to pay, at minimum, $65 for the service visit. I was then blessed with the intutition to do a bit more research regarding the PIP box being stuck on my television and other input functions (Inputs 1,2, and DVD) being unavailable.
I stumbled across a post on the internet that mentioned that the VS50603 can reset certain error conditions by pressing and holding the Input and Menu buttons (simulatneously) on the front panel on the TV while it is off. At some point after initiating this internal reset the LED light should starting flashing at defined intervals. The number of flashes correlate to a particular error code. Please go to the Mitsubishi website and download the owners manual (VS50609 in my case, couldn't locate VS50603) to lookup what the various error codes mean.
It seemed to me that that the LED flashing did not start immediately after pressing the Input and Menu buttons. In fact, I awoke the next morning to find the TV off but the LED flashing 10 times, pausing briefly, then flashing 10 times again. The sequence of the flashes mean something. Here again, consult your owner's guide for specifics.
Long story short, after awaking to find the LED flashing, I then turned the TV on and voila-my big screen was back minus that pesky PIP box prominently displayed.
I hope this helps someone like it helped me!! Truly a Blessing for sure.
Michael in Atlanta
Oct 27, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Video Jumps on Screen
Sounds like the cleaning job wasn't good enough to get all the dirt. Try a Panasonic cleaning tape; if that doesn't work, find a local repair shop to do a good hand cleaning.
Jun 22, 2007 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Televison & Video Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
