Question about Dishwashers
Hygena dishwasher water will not enter machine when turned on , replaced solenoid only works in one position is there a water level switch/indicator/ thats would prevent the programmer from sending 240 volts to solenoid
    President:
  • 1,462 Answers
There is a pressure stat but these are reliable. a common fault is the wiring loom broken where it goes round the corner at the bottom of the door. take outer door panel off and inspect the wiring loom for breakage
Posted on Aug 10, 2008
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Kleenmaid DW3 dishwasher not running.
HI,
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Sep 12, 2008 | Dishwashers
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
My dishwasher is showing error code a10 model ide 1005
Jun 12, 2011 | Dishwashers
Power works no water into unit
hELLO THERE:
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 19, 2010 | GE Dishwashers
No water to dishwasher
There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Feb 10, 2009 | Dishwashers
Water will not pump in .to the dish washer
Water-inlet valve
Float switch
Drain line/air gap
Pump
Belt
Motor
Timer
Feb 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
The machine is not taking any water in
First check the water supplies at the back of the machine.
That is either a problem wit the inlet valve , or with the water level switch.
See the following suggestions from Repairclinic:
Water-inlet valve
Float switch
Oct 10, 2008 | Zanussi Dishwashers
Hygena Dishwasher doesn't fill with water
Sorry that is a UK model and wont have any access on how it works.. but you can check the water level probe (if Equipted) clean it off.......... the elements should only come on once the probe tells the board it has water dont let the element dry fire they will burn out fast when not in water
Feb 04, 2008 | Dishwashers
Not enough water
Be aware that you should remove dishwasher's power cable before touching wires or making resistance measuring !!! Check that the inlet valve get power. In case it does and no water entering the tub, check with multi-meter for solenoid's resistance (disconnect first the wires to it),if no measurement result, you should replace the valve. In case you have a measurement result, remove the solenoid from the valve and check that it's clean from any dirt. In case there is no power to the inlet valve - check that the float switch works. This is usually a small switch attached to a float. The float (usually a cylindrical) located inside the dishwasher at the bottom. As the water level rises, the float rises too. When it reaches the certain height, the float activates its switch, which cuts the electricity to the water inlet valve. If the switch is defective (stuck in the disconnected position)it will prevent power from the inlet valve. The switch is an On/Off switch and you can check it easily by a multi-metr. Good luck !!
Jun 08, 2006 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
226 people viewed this question
Top Dishwashers Experts
