Hello Rogerspray,
I understand that you are having a problem with your GE refrigerator the fan is not working and the power board is not working. The fan should always run when the compressor is on and sometimes when the compressor is off as it is to circulate the air.
You will need to replace the fan this can be removed and taken to any local hardware store and purchased as the are not expensive.
It sounds like you also need to replace your power board. I have located you one on Sears Parts DIrect it costs $91.33 and can be located at this link power board.
In-order to replace both of these items you will need to:
1. Turn off power
2. Remove cover panel
3. Disconnect quick connects
4. Remove item
5. Install new item
6. Replace wire to same terminals
7. Replace cover
8. Turn on unit and check
Replacing these items should take care of the problem that you are experiencing.
Thank you for choosing FixYa.com
Justinbur167
