I have recently had my Saeco Vienna serviced. When I got it home I noticed that they did not fix the problem with the digital readout. Therefore I cannot reprogram it or change the program.
A few days ago, my machine was in "rinsing mode" preparing to make coffee. For the first time ever, I took the water reservoir out to fill it during this process. At that time the "rinsing process" halted, but did not continue once I placed the water reservoir back. I have tried many times to get it to finish rinsing, including unplugging it, turning machine off, waiting overnight to turn on again. but I can't make out what the digital readout is, so I can't follow the instructions the machine might be giving me. It only looks like jibberish, and it will not go past the initial start up sound just before it rinses. I was hoping someone might be able to walk me through a process, or at least tell me what I've done.
SOURCE: Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
SOURCE: Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
SOURCE: Saeco Vienna Digital
You have to replace the "water turbine" in the machine, it´s like a water counter.
I have found that "Eddie" at the Saeco dealer at 7905 Cochran Road, suite 100, Glenwillow OH 44139 with telephone of 440-528-2000 or Fax at 440-542-9173 can fix or answer most everything and he has the repair parts if needed. He can provide a parts diagram to help you too but it is in Italian. Be careful though, he likes to "chin" on the phone because he wants to help..He has solved a number of my problems with my neat Saeco Vienna Deluxe that has kept it running and out of the shop..Hope this helps. Tell Eddie that George sent you.
[email protected]
