Question about Mitsubishi WS-65511 65" Rear Projection Television
Green on screen
I turned on my TV and the green color is messed on it. It is ok on the sides but then in the middle of the screen the green color bends towards the middle from the top and bottom towards the middle. (sort of a concave shape). Any ideas?
    Genius:
  • 1,011 Answers
Try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
Posted on Aug 10, 2008
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
The tv screen is green
This is usualy a bad picture tube. are there any bright lines running across the screen? It would be helpful if you could give the brand and model number
Mar 12, 2009 | RCA TruFlat 27F520T 27" TV
RCA DLP TV with a red dot in the middle of the screen
Sounds like the color wheel stopped and re-started. It may continue to function for a while, but could fail at any time.
I've also seen on rare occasion, a defect in a lamp produce uneven color rendition, but its far more likely that the culprit is the color wheel.
michtech
Feb 13, 2009 | RCA D52W19 52" Rear Projection Television
TV KOLIN 21"
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen ok.email me what happened. jaredreyesbalderama@yahoo.com GOODLUCK
Jan 21, 2009 | RCA 20F512T 20" TV
Tv color messed up
There is the chance that the yoke has sliped and a purity adjustment is in order, since you would be dealing with voltages that could kill you if you don't know haw to do this the safest bet would be to take it to the shop
Jun 03, 2008 | Symphonic ST420FF 20" TV
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
60" Samsung HDTV
Thats a very good possibility. The bearings in the color wheel eventually wear out. Have you noticed any noises lately when the green is messing up.?
Jan 19, 2008 | Toshiba 52HM95 52" HDTV Projection...
RCA MM36100 color problem
sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
Aug 12, 2006 | RCA MM36100 36" TV
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
