Question about Philips 42PF7320 42 in. EDTV-Ready Plasma Television
Philips 42PF9630A/37 PLASMA TV
My TV will no stay on and will go from green light to red light which flashes 7 times. I open the back cover and I saw in the power supply a green led light which flashes 3 times and found that it was a Vscan error alarm/code. So I started unplugging some connectors until I unplug the connector that goes to the board LJ92-01200A which they call a Y-board and the TV stays on and I can control the TV with remote or the side buttons. NO pictures but I connected and input (my video camera) and I can here the sound. Do I need to replace this Y-board?
  • 1 more comment
  • cladams19 Sep 10, 2008
    I am having the same problem. My tv is connected to an HD cable receiver, and a Phillpis home theatre system. If I try to turn the tv on first, the led light blinks green first like it's trying to turn on, then blinks red over and over. But if I manually(not using remotes) turn on my reciever and then home theatre, THEN tv it works fine....explain that? Have you had any luck with yours?
  • ceced Sep 26, 2008
    If you need to replace the y-board--good luck. It is on factory back order with no date of arrival. My tv is 2 1/2 yrs old--out of warranty--It has been at the philips recommended repair center for 2months. Philips recommended that the repair center actually try to fix the part themselves--of course the tv repair center doesn't really fix --they only replace. They will not use a reclaimed part.--I'm begining to feel SOL!!!!!
  • Anonymous Oct 06, 2008
    My TV repair shop (Philips recommended) has had my Philips 42PF9630
    A/37 for 2 months and can't get the Y- board. It is flashing the same code (7 red blinks) and won't power on. This really sucks. The set is almost 3 years old and parts are not available.
    keith_nun@yahoo.com
  • 138 Answers
Replace that board the part number is 996500032643. go to www.vancebaldwin.com for the price of the board.
Posted on Aug 20, 2008
Phillips flat tv 42PF9630A Will not turn on and power light flashes red 7 times
The power supply board it is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Mar 06, 2011 | Philips 42PF9630A 42 in. Plasma Television
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Oct 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
The TV normally has a green light illuminated in the lower left. Now there is a red blinking light (7 times) and the TV is not responding to any TV buttons or remote commands. If I unplug and plug back in,...
Philips Televisions are legendary for having faulty power supply capacitors.
In order to prevent really bad things from happening, the TV does a two-stage power-on. It first does a basic diagnostic test, and if that fails, it stops it from going any further.
Philips tends to use cheap capacitors, use capacitors that are somewhat under-sized for the job, and also seems to be pretty bad at soldering.
Personally I've got my Philips LCD TV opened up on my workbench for that exact problem.
Most repair shops would replace the whole power supply board ($150-200 part plus labor), while most DIY fixers take a stab at replacing the obviously bulging and failed caps for less than $10.
Oct 07, 2009 | Philips 42PF9630A 42 in. Plasma Television
I have philips plasma tv model #42PF9630A with ambient light
last time I had seen these syptoms on Philips plasma it was bad panel. Replace tv panel is too expensive to replace.
Aug 29, 2009 | Philips 42PF9630A 42 in. Plasma Television
37' philps flat tv
4 blink error for that model is i2c communication failure specific to ssb (small signal board) if intermittent should upgrade firmware to newest firmware and if constant would need to replace small signal board
Aug 18, 2008 | Philips 42PF9630A 42 in. Plasma Television
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Jun 27, 2008 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF7320 42 in. EDTV-Ready Plasma Television Logo
2,581 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
