Hi, Expert: I am using NETOPIA 33347 wireless Router for home networking. I can not reset the router for my wireless laptop computer. Wireless light is not turned on and can not access to router from my laptop computer. I tried to setup through window wireless setup. However, it does not working. Please help me out. Jay/ imjay53@yahoo.com
    Novelist:
  • 148 Answers
Greetings my name is Mark and I will be glad to assist you. First unplug the router power and let it stand for thirty seconds. Second locate a small hole in the rear of the router it will not be marked. Third insert a small paperclip in the hole, you will feel a click when you do this, hold the clip in place for thirty seconds, at the same time you are holding the clip in place re-connect the power to the router and count to thirty seconds. Remove the clip and allow the router to re-boot for two minutes. It will reset to factory default and you will be able to access the router through a hardwired computer connection. Open your internet explorer and in the address bar type "192.168.1.100" your user name is andmi and your password is admin this should default your router and you can make the necessary security changes. Take care,
Be mucho blessed,
Mark
Posted on Aug 10, 2008
I reset my Netopia Cayman 3347W wireless router and now my Laptop is not able to use the Wireless signal as it states that the connection manager is set to use only secure wifi but the reset signal is not...
You reset the router. that means router is set on factory default.settings has been changed now that's why connection manager is not responding properly. Now you have the run setup CD and set the router again.
Oct 11, 2012 | Netopia Cayman 3347W-Ent Wireless Router
I'm trying to find the WEP for the netopia router where do I find this
Welcome to Fixya. If you want to obtain the Wep Key or Network Key on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1. Go to the Wireless Settings Page you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure.
Thanks for using Fixya.
Feb 06, 2011 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Where do I find the WEP key code on my modem model number 2247NWG
the network administrator (whoever configure your router) should have the wep key you're looking for, if you're that person and forgot your wepkey you need to reset your router so you can go back into the router configuration page and reset a new key (and hopefully you'll remember it next time).
here some instructions for your product:
check on page 14 (FAQ) of router's manual
resetting router to default configuration (router's manual)
good luck!
Dec 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
Wireless not working, went into setup and enabled
1. Please make sure its the router and not the laptop. can you get the laptop to scan for other networks . this is to make sure that the issue is with the router and not the laptop. 2. goto the setup again and try changing channels to 11 or 4.
Thanks
Ranjit
Oct 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia 3347 wg not giving wireless signal. its ok when connected directly. was working ok last week. Q6
This is a problem with the routers firmware so to correct this better do a firmware upgrade with this unit and you can get the firmware from the manufacturer....
Sep 15, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
LImited or no connectivity on wireless router after reset
hi
go to the router wireless settings and check to see if the wireless connectivity has been disabled as a part of default settings
cheers
Pls rate if this was any help
Jul 04, 2009 | Microsoft Wireless Network Adapter Xbox...
Netopia 2247nwg router
Well I'm no expert on routers, but I've never heard of Netopia. If you can, try Linksys routers, they're so easy to use and they have the best customer service. I have a Linksys WRT-54GL Wireless Router linked up to a Wireless-G PCI adapter. I wont lie to you, Linksys is very easy to use, and you can see any activity on your network straight from your computer. I got my setup for less than $50.00, but I don't know if they got cheaper or not. They're blazing fast too, they can transfer data up to 54Mbps or higher, I've never used anything quite as simple as a Linksys router, I did have and old Aris router, but it was too difficult to use, so that's when I bought the Linksys. You won't be disappointed!
Hope this helps some!
Oct 05, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock my router?
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock netopia 2247NWG
Feb 10, 2008 | Netopia 2247NWG-VGx Wireless Router...
Computers & Internet Logo
David Payne
David Payne
