Question about Magellan MAESTRO 3100 98083401 GPS Device
Low battery, wont' charge in car - Magellan MAESTRO 3100 98083401 GPS Device
  • GRANDMAGEN07 Dec 27, 2008
    MY BATTERY SAYS 81% PLUNGED IN WHY NOT 100% HOW DO I DO THIS
  • byrd5 Dec 29, 2008
    My Magellan Gps won't charge in the car either. Is there a way to replace a battery?
I havew the same problem but the thing is i upgraded it and as soon as i upgrade it it wont charge anymore i always get a result of battery low, sleep mode everytime i turn it on i even bough a new car charger (universal) for this please help
Posted on Nov 10, 2008
I pushed the reset button, on the side,during the brief moment that it stays powered up. Now it is staying on with the wall plug.
I'll let that stay on for a while and then try to keep charging it with it turned off.
Posted on Aug 15, 2008
PTO wont engage unless battery is charged up
Dale, it is normal for the PTO not to engage when voltage is low. Have battery and charging system diagnosed and repaired.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Charging System Battery Alternator Test Briggs FAQ
CHARGING SYSTEM MAINTENANCE
LAWN MOWER TRACTOR ZTR HOW TO TEST SMALL ENGINE VOLTAGE REGULATOR...
May 25, 2016 | Cub Cadet Garden
I have a 1997 chevy Malibu and it runs find during the summer months, however when the temperature drops to 50 degrees or less the car wont start. when it warms up it starts. why wont the car start wh
battery is too low rating for car to start in winter. Or battery has bad cell and will hold a full charge needed to start, or the alternator is not putting out a full charge to the battery .......
Oct 14, 2014 | Cars & Trucks
Battery draining
Check the water level in your battery cells. Low levels wont let it hold a Charge. . .
Mar 28, 2013 | 2006 Chevrolet Silverado 1500 2WD
Battery wont stay charge
several possibilities here... always try easiest/cheapest first.. A. loose or corroded battery terminals. B.check water level in battery , add if low then try a charge..C. could be bad cell in battery have load tested, and finally D. alternator may be putting out inadequate charge, have checked
Sep 27, 2012 | 2003 Kia Optima
My 2004 SE 2L wont start. when i try to start it it makes a triggering noise from the bonet. It was running low on petrol plz help
This sounds more like a low battery. Try to jump it if possible. If not, try removing the battery and taking it somewhere to have it charged. Once you know you have a good powersource(i.e. battery), then try start. If it does, then have your charging system tested for proper charge.
Feb 20, 2010 | Hyundai Motor 1999 Tiburon
Battery light and brake light were on, card wont
Nissan truns the brake and battery light on when there is a charging issue. When you say it wont start does that means it craks or no? If it does not crank I would attempt to charge the battery then try to start it and check the charging system.
Feb 18, 2010 | 1996 Nissan Maxima
Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
May 02, 2009 | Honda Accord Cars & Trucks
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
Recharge
you probably have charged the battery when it wasn't empty and got a memory effect
Nov 12, 2007 | Samsung YP-U2X Digital Media Player
Magellan MAESTRO 3100 98083401 GPS Device Logo
219 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
