Question about Sony Walkman NWZ-S616F MP3 Player
My Walkman is going berserk
Well every time I insert the Walkman into the computer or an outlet...A message says LOW BATTERY MUST CHARGE...also the sony Walkman screen logo stays in one place...I have no idea why this is happening
  • jenteara Aug 14, 2008
    when i plug the cord into the computer and into the walkman the charging sign wont come up . it jus stays on the song im playing
  • Anonymous Sep 05, 2008
    my mp3 wont charge
  • 62 Answers
When that happens you want to get some thing sharp and hit the reset button on the bottom of the Walkman
Posted on Feb 26, 2009
2 Suggested Answers
SOURCE: My Walkman won't charge
What I did when I got this error was to push the reset button on the bottom of the player itself... Mine rebooted and took a charge from the computer. Hope this all works for you.
Posted on Jan 01, 2009
Charging does not charge
If your Notebook computer battery is not charging, try the following:
  • Reset your computer's power manager. For information on how to do this with your specific model, search Apple Support.
    • Make sure your AC adapter is properly inserted into your laptop.
    • Connect your computer to its AC adapter, shut it down, and then let it charge overnight. If it does not charge, it's likely you have a hardware fault in your computer, battery, or adapter, and you should have it repaired.
    • Test your AC outlet. See if your battery will charge if you plug it into a different outlet, or see if another electrical device will work in your original outlet.
    • Test your AC adapter. Try connecting a different AC adapter to your computer and see if it recharges.
    • If it's removable, test your battery. Try using a different battery with your computer and see if it will recharge.
    • In some of the early PowerBooks, the battery will not charge unless the computer is turned on. If you have an old PowerBook and your battery isn't charging while it's turned off, power it on, put it to sleep, and then see if it recharges.
    If you go through all of these steps and your battery still won't charge, or you can't narrow down the source of the problem, you will probably need to have your computer repaired. However, it may be worth your time to consult Apple Support first. It contains entries on problems with specific computer models and versions of the operating system, including battery recharge issues.
Aug 10, 2010 | Apple MacBook Air Mac Notebook
I've been using my Sony Walkman NWZ-S615F.it seems like my player won't connect to my pc the same one I've always used with it. It ran out of battery and when I connect it it switches on but just says...
The same thing happened with my s616f and I just fixed it today. Connect your walkman to the computer to charge it then when the blue screen pops up heres gonna be that blue line going across the screen(the thing that shows that its loading) then while its loading press and hold the back/home and the option/pwr off buttons until it turns on. Hope it works:)
Jul 15, 2010 | Sony Walkman NWZ-S616F MP3 Player
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
My player was turned out because of the low battery and now i can't see how the battery is charging...I can see only the name walkamn shining on the screen - this is it! (the player is connested with...
Hi lybastr,
I guess you have to let it charge awhile. When the battery gets too low, it might even refuse to go past the welcome screen. Let it charge for an hour or so. If the screen is still stuck on "walkman", then you might have a problem, but that's not common, so rest assured.
Jan 02, 2010 | Sony Walkman NWZA726 Digital Media Player
My walkman will not charge. I left it on charge
Hi joanna,
It is probably not turning on due to extremely low battery. Have you been using it for quite a few years? Then there may be a problem with the battery. But before that, please try connecting the player to another USB port on your computer, or removing any USB extensions except what SONY provided, or upgrading your USB driver. If nothing works, I'm afraid you'll have to refer it to a service center.
Oct 22, 2009 | Sony Walkman NWZ-S616F MP3 Player
Walkman won't charge ,plugged into computer for 1 hour, but comes up low battery and switches off
I pressed a pin into the" reset " on the bottom of walkman this seems to have done the trick
Jul 17, 2009 | Sony Network Walkman NW-A3000 MP3 Player
Walkman NWZ-S616F doesn't charge when connected to computer.
Here is a link to instructions. I found my fix for frozen S616F was to use the Reset feature. It requires inserting a small pointed object in the hole at bottom of device.
http://www.docs.sony.com/release/NWZS515_S516_S615F_S616F_S618F.pdf
BenN
Jun 05, 2009 | Sony Walkman NWZ-S616F MP3 Player
Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Jan 02, 2009 | Audio Players & Recorders
Aug 10, 2008 | Sony Walkman NWZ-S616F MP3 Player
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Sony Walkman NWZ-S616F MP3 Player Logo
232 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
