2002 Jeep Grand Cherokee Logo
Posted on Apr 25, 2011
My 2002 GC 4wd automatic trans 4.0 engine shuts down only when the outside air temp is above 80 degrees. When approaching a red light / stop sign, I let off the gas pedal and at times it will shut down rpms gradually go to zero. At cruise, 50 mph the engine feels like it shuts down and starts up again. very abrupt and sudden with no codes. Dealer can find nothing wrong. I replaced the Idle control valve, did not help much if at all. PCM? When it shuts down at low RPM, I can start it right up again, no problem.
A
Anonymous
If a dealer can not fix it, we can't guess at the unknown
Now your involved with a dealer leave it there, until
they solve it. Somebody has to stay with it, to a successfull
conclusion.
You could ask around about repair shops that are good at
diagnostics & drivability issues
Chevy G20 1992 - 6 cylinder. Running rough when air temperature is above 85 degrees
"Seriously I don't know why more people haven't tried this, I work two shifts, 2 hours in the day and 2 in the evening...And i get surly a check of $12600 what's awesome is I m working from home so I get more time with my kids.Here's sign up
for details....... http://bucks2.com/
2answers
2002 chevy malibu heats up when running at low speeds
CHECK THE THERMOSTAT. THERMOSTAT IS THE ONE THAT SENSE THE ENGINE TEMPERATURE AND TURNS ON COOLING FAN WHEN THE ENGINE IS HOT.
I have a 2001 2500hd Chevrolet with 6.0lt engine that when the outside air temp get 80 degrees or above the engine will shut down and will not start till the truck engine cools down and when it is 90...
Have you investigated the cooling system. Inspected all of those sensors? Normally a bad sensor would throw a code out, but it's worth a shot. Also go to basic stuff. Just throwing out ideas, flush and fill, thermostat, etc. Sometimes the biggest pain in the but is the easy stuff.
Hope this helps! Don't forget to rate.
Gtaplytmpt
My 2002 jeep grand cherokee when the weather goes above 100 degree it starts to stall went i stop at a red light or stop sign.
Hmm ... this sounds like a classic case of vapour lock. If the temp gauge does not go up (Which could indicate a bad head gasket, a clogged radiator, a dead fan, a bad water pump), then what is most likely happening, is that the gas is getting hot enough to boil, and is doing just that: Which makes it impossible for air and more gas to be drawn through it, effectively suffocating the engine.
Air temp indicator only reads temps below 50 degrees
Ambient air temp sensor could be the cause. Normally located in front grille area.
5helpful
2answers
Air Conditioner stops blowing cold air when vehicle is not moving
plus one on the cooling fan problem. if it was low on charge then as you slow down, condensor temps and line prressures would raise therefore it would cool at low speed and and not when moving since the incoming air would drop system temp,reducing line pressure and then cusing compressor to cycle. the auxillary cooling fans must be on whenever a/c is on, if not, thats your problem. get this taken care of because if you get stuck in traffic, your engine will overheat also if fans are not running
2002 gmc van overheatig
It has a leak. Fill up the radiator and the coolant tank. Then restart it and check for leaks.
1helpful
Why does my car vibrate and noisy at red light and stop sign
Maybe it's the transmission itself. check it.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
