Question about LG WM-2277HW Front Load Washer
Washing machine WAsing machine will not spin
  • 639 Answers
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
Wasing machine washes fine, once it gets to the spin cycle it stops and just makes a slight hmmmmmm sound. and wont drain or spin.
Wendy,
What brand of washer do you have? If you put that info in, it did not come through with your question and we need that info to give you the correct information to help you fix your problem.
Jun 23, 2015 | Washing Machines
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Mar 11, 2014 | Beko WM5140W
Wasing machine stops spinning during final spin - 3 or 4 minutes into the cycle.Frigideaire front end loading washing machine.
You could be using too much soap that will cause the machine to go in oversuds motor protect and shut down . Do make sure you are using HE soap and only about 2 to 3 table spoons per load .The next most likely cause would be the door lock but I think you have a soap problem..Good luck need more help please ask Thanks for Voting
Mar 13, 2011 | Frigidaire ATF6000ES Front Load Washer
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Washing Machines
After wasing dark cloth, there a lint on them, how
i think the paint inside the washing machine started to peel,and maybe that's the cause of white lint.
http://www.washingmachineadvisor.com/1400-spin-washing-machine
Feb 05, 2010 | Washing Machines
My wasing machine will wash the cloths but will not drain the water out and spin plz help
Check your drain filter as it's probably blocked. Do an emergency drain on the drum first though or you will flood your kitchen - and turn off at the mains first if you can water and electricity don't mix.
Jan 21, 2010 | Washing Machines
Samsung fuzzy wasing machine WA75N6
sad to say, he is correct. when all indicaters come on together and do not extinguish, the board needs to be replaced
Aug 07, 2007 | Whirlpool LSB6200KQ Top Load Washer
LG WM-2277HW Front Load Washer Logo
43 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
